First wash with the new rims. Apologies for crappy iPhone pics!
That's okay mate, we got some better ones last night! :) (I think these are the best 4?)
Edited by 32godzilla
I'm always down with skylines period... Especially gtr's how ever if the right money and time is spent on a gt-t for example mine very few gtr's can keep up lol but still have to agree solid gtr community on here
Mine is not pretty for photography but goes alright WHEN it goes :D Will try get the group shot on the 21st where there will be around 5GTT's and 3GTR's together :yes:
Great images 32godzilla what you using and what techniques?
That's straight to the point!! :)
Not easy to say though because I do every photo a little bit different depending on what style I'm trying to achieve. That said, I normally process my RAW files into smart objects and layer a couple together. I use overlay a lot as well, stacking a couple of layers on top and playing around until I get the look I want. Smart objects is your friend!!
I like this one below because it was one of those random moments when you think, quick there's a good shot here!! I wasn't quite ready to go, so had to rush pretty quickly to get the shot, and one of my speedlites wasn't firing so I did what I could. Handheld at 1/60sec lying on the ground wasn't that easy, but Nikon's VR system does wonders! :) (Shot using a 70-200mm 2.8 VR2)
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
