finally got my car lowered on the weekend, been a long time coming ha.. pretty happy with the way it sits now, also new tyres!
pretty average pics but here they are..
Great to see big bird flying a little lower.Nice work looks the goods :yes:
...better not park this next to Shell's R34
> turn your back for 1 minute
> you'll be left with her car and your number plates on it
Here are a few of mine the day it arrived in Victoria.
So nice!
Endless Brake setup is awesome!
What aftermarket carbon fibre part is that above the diffuser?
Or is it just painted black?
Looks a lot better now!
Car looks amazing mate, soo clean and simple but still soo aggressive
Thanks.
BSB on white looks awesome too!
Thanks.
Ive never been a fan of the carbon high wing stands on anything bar white or silver but your BSB pulls it off very nicely !!
I was also not a fan and thought I would put the standard stands back on, but once I saw it in the flesh I decided it looked good.
So nice!
Thanks.
The rear section above the diffuser is a "Superior Auto Creative" carbon panel that is clipped / double side taped to the body.
http://www.nengun.com/superior-auto-creative/carbon-rear-bumper
Well once again, mine is just a GTT and not the prettiest thing but also lowered it on the weekend by an inch and did some tidying up -
Heap of other pics in the build thread but no point flooding the page with a daily :P
Thanks.
http://www.nengun.co...bon-rear-bumper
I see, thanks!
Looks quiet good.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
