I'm sure it will mate! Your 34R is the best I've seen in yellow. I got one set of stickers previous to those but I didn't like the outline, so found the red set which were perfect
Cheers mate. Yea ny wheels are te37sl but I didn't like the red with the yellow, so will see how they work out. Will post pics once there on.
Dang son, very well done. What are the specs on your wheel fitment?
Also, how did you tint the reverse lights?? DIY?
Cheers Tom,
19x9.5 +12 all around, front and rear guards are both rolled to flatten the lip and pulled out a few mm.
Reverse lights are tinted using a gloss black tint film (not like window tint) i stock, as were the rear indicators which i now have precut pieces to suit 34 tail light indicators. The beauty of it is when you throw it in reverse or put on your indicators they are still clear as day, almost no reduction in brightness with the tint film on.
Cheers Tom,
Sounds the goods Stephen, I just bought some cst zero-1 hyper in 18x9.5 + 15 all around, so the fitment should be very similar to yours :yes: . What tyre sizes are you running, and do you get any scrubbing on full lock?
Considering you run a graphic business, I'm guessing you can supply the tint film?
PM me details if this is the case :thanks:
Ah very nice,
Tyres are 235/35/19 up front and 265/30/19 rear.
With the front plastic guard liners removed there is almost no scrubbing on full lock.
I'm thinking of adding camber arms to give it just a little neg camber and also hopefully help it tuck more when leaning into a corner/going down a large dip, as if i corner too hard it will scrub a little on i believe the guard. Also going down a dip really fast which naturally compresses the coilovers tends to cause a little scrape.
Will send you a PM regarding the tint film.
Some pics I dug up off my hard drives.
Love em!!
Hey thats my car :) , geez long time since that photo taken some changes since then. ( wheels, bonnet :) , some slight damage to lower lip :( )
Glad it made it onto the must keep photos lol
Its actually a Fluro Orange, (Which you prob still might not like lol) the shitty iPhone Camera does not even show you how bright these are, thought they would be something a bit different for summer.
They were originally a white rim and I Plastic Dipped them.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
