^^^ Love the colour combo/contrast.
Looks distinctly familiar somehow :)
DarkChild has been at this game for a long time know, definitely knows what he's doing ;)
A very well known 34 R, one of the original Stormtrooper 34R's really - inspired tangomatts 34 to a large degree - well played, well played :)
Thanks for having us today Terry, was a pleasure to meet you! :D
You're most welcome Jasmine :)
Really lovely GTV - but different shape to my '79 Alfetta hehe...
Here's another rear end shot you might like...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
