This is the Nismo kit (s-tune):
Yours is the factory Altia aero package option
#@cooke24 sorry mate i have the same as you, we don't have the nismo kit. the nismo kit looks proper sexy but alas it's quite rare to find! speaking of which that yellow one is/was for sale in Aus a few months ago...
Aight good To know still hard to find, I wouldn't of bought a 34 without the altia kit
19 x 10.5 +12 wheels
285/35/19 Tyres
I'm actually getting rid of these to go back to an 18" wheel again.
Anyone interested please PM me..
they look so chunky, would think they would scrub unless you have the inner guards removed or something? mine scubbed on similar spec wheel with 275/35..
ive got 18s going on mine this week but and running 295/30... have heard there should be no scrubbing issues!
Looking good sean! Im thinking of getting the same wheels for my car. Do you have any side on shots?
Earlier pic with stock height, side view of wheels for ya.
One of Matt's photoshoot pics :)
Thanks guys, was a good turnout of 34GTR's at the All stars event in the Gold Coast too!
Haha won't be back down for a while!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
