hey adam, not sure if it's just the angle of this pic but does your cannon hang to the left? cos mine does, and noticing yours, it's kinda curious that both ours do (if yours does).
PS: a bit of the meguiars plastic trim restorer (or equivalent other product) will make the grey grids on the bottom of the rear bar look nice and schmick
There are plenty of exhausts that hang to the left. Its normal.
hey adam, not sure if it's just the angle of this pic but does your cannon hang to the left? cos mine does, and noticing yours, it's kinda curious that both ours do.......k
I took Maria to a movie the other day > get her out of the 4 walls.
At the cinema, I parked slightly to the left.
She got out of the car and looked at my car's alignment.
I knew what she was going to say, so I yelled, "Have you ever seen a penis that hangs straight!"
She laughed and then enjoyed herself :)
That black and white pic looks nice. Got some character to it!
Spent the day smoking the front lights because they were faded and ugly and also did the grill bit...opinions?
I like it, looks more aggressive but isn't just another GTR knockoff
hahahaha good story Terry. Guess i'll be content with my hanging lefty aye
Haha the black one is cleaner ;)
Give it a few days lol
Yeh it does, it's a HKS cat back.
Cheers!
The lowness looks great, however impractical it may be lol, but not really feeling the headlights, just looks cloudy rather than smoked.
My idea of a smoked headlight/tail light should be a tinted effect whereby the clarity is still glass like (or as glass like as possible with the damn 34 headlights) but just darker.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
