i got the front fenders from carmate.com.au ... and my rear wide quarter panels are coming from ebay>>>..china
once i get em will have to rivet them in ... :D :D then will take a couple of shots with them installed..
Cant wait to see yours with the riveted fenders that exactly what i want! haha
The only rear fenders I've seen need a gtr rear bar tho because they have the step out
I'm actually looking at flares on the front fenders, will be a bit of work to get it fitting good but may be worth it, only seen it once on this:
Why'd u go from one R34 to another? GT->GT-T? Looked clean!
nah still on P's brah, but thanks! so went from mildy modded auto gt to bit more modded manual gt. got rid of that one because the front two strut towers split :| bought from a dealer and he did a bodge rust job so yeah learnt my lesson. :(
Ahh yehh makes sense, I saw sooo many Gts-t's with rusted strut towers when I was looking for mine! Plagued!
  • Like 1
It's crazy! It happens to 34's way too much, definitely plagued. Same with the boot lining of some I must add! :/
May this be a warning to anyone buying any grey import from any countries that salt their roads.
