Have you got a side on shot now its fitted mate? Been keen to do the same but worried itll look odd :S
Will take one if i get a chance today.
I have nismo rear pods as well, so it will definitely look a bit off until i find a suitable side skirt to match the front and rear.
I have pretty much the same styling too and was expecting the ztune style sideskirt add ons to suit. have you done a test fit with yours?
What headlight polish does everyone use? My polish ran out so lights are yellowing up again. :(
^^ Cars are looking mint btw guiseee! :wub:
Plast-X seems to be OK mate!
Thanks for that! Just trying to get an idea on what to do with mine without taking away too much of the stock look!
  • Like 1
Yeah the nismo (ztune) skirts don't bolt up under a GTT, i sold mine for that reason.
Might hit up viva garage for their version of the nismo skirts, comes attached to a larger part that attaches to the stock skirts.
yeah that was the path i decided to take too, although have been considering some rather out there options lately since it is soon to be decked out in business livery as well.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
