Great pic J_R32!
Hnnnng. I'm yet to see a good R34 GT-T meet in perth..
Here's a meet :)
http://www.skylinesaustralia.com/forums/topic/439379-official-sauwa-sunday-brunch-core-cider-house-pickering-brook-23rd-march/
(disclaimer: may or may not be other R34 GT-Ts in attendance)
Very nice cars both of you!
The things I would do for a blue GTR
And the unspeakable things I would do for a Z Tune
Awesome pics!
Thanks guys, appreciate it.
A mate and I will be starting the engine work soon, so she will be off the road for a few weeks.
Will need to get some proper pics soon.
Thanks Terry, altough I prefer them with the collar or the plain LMGT4 plates i suppose those could be machined, just might have to send him a PM if i can get a machine shop to give an estimate on collars to match. Been looking all over so thanks again.
Hi guys - we had a little meet over here in WA last weekend, we didn't quite match Sydney's numbers, but we managed 14! Here's a little video from the meet, hope you enjoy! :)
(Terry, you may notice another white N1 there..... absolutely mint condition with @ 12,000 original km's on it ;)
Edit: and just seen the other pic from the meet on the previous page...
Edited by 32godzilla
  • Like 1
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
