Great pic J_R32!
Hnnnng. I'm yet to see a good R34 GT-T meet in perth..
Here's a meet :)
http://www.skylinesaustralia.com/forums/topic/439379-official-sauwa-sunday-brunch-core-cider-house-pickering-brook-23rd-march/
(disclaimer: may or may not be other R34 GT-Ts in attendance)
Very nice cars both of you!
The things I would do for a blue GTR
And the unspeakable things I would do for a Z Tune
Awesome pics!
Thanks guys, appreciate it.
A mate and I will be starting the engine work soon, so she will be off the road for a few weeks.
Will need to get some proper pics soon.
Thanks Terry, altough I prefer them with the collar or the plain LMGT4 plates i suppose those could be machined, just might have to send him a PM if i can get a machine shop to give an estimate on collars to match. Been looking all over so thanks again.
Hi guys - we had a little meet over here in WA last weekend, we didn't quite match Sydney's numbers, but we managed 14! Here's a little video from the meet, hope you enjoy! :)
(Terry, you may notice another white N1 there..... absolutely mint condition with @ 12,000 original km's on it ;)
Edit: and just seen the other pic from the meet on the previous page...
Edited by 32godzilla
  • Like 1
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
