Thanks Terry! Same goes to you and your very neat N1 R32
Thanks Chris! Have we met?!
I saw you (and the car) on the day, however, we did not have a chance to chat.
Was a hectic day lol.
Will hopefully have another opportunity at a few upcoming events :)
  • Like 1
  • 3 weeks later...
Thanks Chris...
Still at the Car Show. And thanks again to photographer Kennedy Maeder.
Badass shots - all.
On the way to Castle Hill, Google Maps took me all the way out to Arcadia > Private property.
If someone in there was doing some hacking, I'd like to know how they're doing it.
Maybe I can set it up at my home and bring in all sorts of cars going up the Blue Mtns :P
  • Like 2
Thanks Chris...
Badass shots - all.
that is PLUSHHHH
  • Like 1
