  • 5 weeks later...
This is my GTT over the years
The day I bought it off FLN75S901438_10152700515230198_1347706032_o.thumb.jpg.4132ab0120848486b143b211a0ffda04.jpg
Lost the lip and was wingless for a bit
11538977_10155672167515198_6519762481535571487_o.thumb.jpg.117720b0f19ba878b22141052f178c5b.jpg11010501_10155672167315198_2191215101598066288_o.thumb.jpg.9f0b5d227e7dd736a46af724e279225c.jpg
Got some SSW Driftr wheels (TE37 replicas)
11058565_10155753071965198_5020753380228039855_o.thumb.jpg.2c7a9fa8f70992c1ccb6aa886b4dd400.jpg
11781883_10155796487990198_2376410430343795023_n.jpg.2da681d7b4e9e39bf5fdf690b64702af.jpg
Got a carbon fibre replica GT-R wing with higher wing stays
12657400_10156405212525198_6515840979751577195_o.thumb.jpg.2c5cf05161eed3023a093771dbd6e7c1.jpg
Then I got an Altia bar and JDM style platesIMG_1119.thumb.JPG.302e768248206501e364006eda142d34.JPG
and this is how she is currently with AME TM-02 Tracers and Bride Brix IIs19780756_10158781817305198_3694660254643074733_o.thumb.jpg.dc717e84c35130e583a1fad12a1ce664.jpg
17390841_10158237952050198_775973085820717962_o.thumb.jpg.3f07e774938039af522aff54823de905.jpg
19024985_650056201864976_3616339785100149794_o.thumb.jpg.5d1e2b11b90bcd00405485ad451ea1bf.jpg19025188_650055771865019_7613867931626438230_o.thumb.jpg.a9b59f0790c575d62a1412d96d539dde.jpg
Last 2 photos by HP Photography
Edited by vinceyboy28
  • Like 1
Playing around near home on a winter's afternoon!
This car looks amazing, the stock bodykit with the front lip and sideskirt extensions look perfect on a gtt. Not a fan of the nismo front bar or gtr bar on gtt.
What specs are those rpf1's? Looks like your running a fair bit of camber.
  • Like 1
Thanks mate! :D
The wheels are 17x9 +22 all round
I think the camber is a combination of the camera angle and from installing a new subframe and coilovers and not getting an alignment yet :( When they are flat they fit fairly well :)
  • 1 month later...
  • 4 weeks later...
  • 2 months later...
  • 6 months later...
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
