  • Replies 200
Dan,
Once we have all the deposits and go to make the booking we'll post the time. It's pretty much going to be an all day event! :)
Sorry man looks like I won't be able to make it tomorrow night. I paid the $25 deposit into your account with the details supplied though. I'll have to catch up with people sometime before the event.
So this is what it looks like so far:
List:
SL33KY (Emily & Daniel + 1) Deposits taken
Bluprint deposit taken
Sinista32
CeJay
Cef11e
LTSJayce Deposit taken
Contempt deposit taken
supadan
Jai Jai (possibily)
Veilside R33 Deposit taken
Skylvia
a20089 Deposit taken
James (sorry don't know your screen name) deposit taken
TONIGHT WILL BE THE LAST NIGHT TO GET YOUR DEPOSITS IN. IF WE DON'T GET THE DEPOSITS BY SUNDAY EVENING AT THE ABSOLUTE LATEST, THE DATE WILL HAVE TO BE CHANGED UNTIL WE RECEIVE ALL DEPOSITS BECAUSE WE'RE SHORT FOR A FULL BOOKING FOR OUR TEAMS.
Well there's 15 people (need 1 more) Baaaaaaaaaaaaaaaaaconer *hint hint* lol :) if you can't EFT we will be out tonight if you need to meet up! If we can get the last few deposits tonight (I have PM'd all those who are on the list and have not paid yet) we will have our full 16! COME ON GUYS!! :laugh:
List:
Sinista32
CeJay
Cef11e Deposit taken
supadan
Jai Jai (possibily)
Skylvia
Just a quick reminder this is available to anyone it is first in best dressed so if your not on the list it doesn't mean that you can book your place on the firing line. So if you are interested just deposit your money tonight at the museum or online,
Account No 10294940
BSB 062593
Account name Daniel Young
Branch Commonwealth Bank
So first in best dressed
Just letting everyone know that from the look of it (unless some weird miracle happens) it will be the 24th of feb. If it is, all those interested in coming, would the idea of hiring a minibus or something along those lines interest youse seeing as none of us want to take our lines. I that souns good to those wanting to come at a later date and the originals please just post either a YAY or a NAY.
Just seems like the most senisble thing to do all we have to do is arrange a meet point and go from there and i think a20089 if you still up for it maybe yours as there is plenty of car space :P
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
