ok painted my wiper blades in black last weekend
back and front left ones came out good
just other one went crap on my as it got bit dirty when can ran out on its last coat and then i said it all back down (maybe sanded it down bit to much.. back to steel)
how now i got new paint and spray it and it drips and all that crap
i sprayed like 6-7 coats and it keeps coming out crap
anyone know how to get it back ready to paint
or should i just go get a new one
https://www.sau.com.au/forums/topic/14675-painting-wiper-blades/
you should probably sand it back to metal then spray it with a couple of coats of metal primer (from any good hardware)
then once you have let it completely dry, spray with fine coats of black paint
you have to make sure you are patient and let each coat dry
also try and only spray really fine coats of paint, if you try and spray it fully black in one coat it will most likely run and stuff it up again
hope this helps
Have had a little bit of experience with painting metal (no I am not a spraypainter, but have had to paint ships).
Preperation is the most important part.
Lightly roughen up the surface with a fine grade paper, 400 or similar. This gives the paint a surface to stick to.
Make sure just before you apply a first coat of primer that you wipe the surface over with prepsol or thinners.
Apply the paint evenly, not too thick or it will run - so light coats are good. Keep the painted surface in a dry place and away from any dust.
Best results on days of over 25deg C (not vital), but low humidity. If the humidity gets above 75% I wouldnt touch it.
A couple of coats of primer, three or four light top coats. Clear coat, I am not sure how necessary this would be on wiper blades. Shiny blades would reflect a bit of sun and might be annoying when driving.
Make sure you use the same type of primer, thinners and topcoat, ie all enamel or all acrylic. This is very important.
If you have to sand back at any stage, make sure you use thinners or prepsol again before painting again.
Just my 0.02c worth. I have got most of my experience with large areas and brushes, not small stuff with spray cans, but I have done both.
steve is correct.. i was a spraypainter/panel beater for over 2 years.
with things like this to paint the easiest and best thing to use is scotchie... that stuff ya mum uses to scrub down pots and stuff like that. its better than using paper and much easier.
make sure there are NO shiney parts on them... shiney means it wont stick.
once its all scratched up... prep, prime and paint.
  • 2 months later...
same question as talej, one of my bolts comes off, the other doesn't. and bolts on or off, the wipes wont come off?
i painted mine exactly as above, sand, primer, thin coats, two light clears, but all while on the car, newpapered and covered it like anything. but couldn't take off the actual wipers?
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
