Hi everybody,
I am planning to take my R32 to its first run on dyno this coming thusrday, and i am seeking your advices and any tip that helps...like should I raise boost when on dyno or jsut stick to 1 bar?>(tuner's advice)
here are the major mods:
RB25DET Series 2
Garret T04E turbo
3" FMIC
Custom 3" air intake piping
BOV
Turbonetics Evolution wastegate
custom 3" downpipe
Tomie cams (270/8.8 both)
HKS metal head gasket 1.2mm
Walbro 255 in-tank fuel pump
HKS 555cc injectors
SARD standard fuel pressure regulator
Centerforce single plate clutch
HKS N1 muffler with custom 3" exhaust pipes
Greddy Profec-B Spec II
Apexi Power FC
Edited by Light
https://www.sau.com.au/forums/topic/146761-dyno-first-run/
your tuner will tune the car to its potential. so if he thinks it can take more than 1 bar then he'll turn it up.
from the sounds of your setup, it will depend on the maximum allowable flow of your turbo.
also, you havent listed an AFM in your list. is it still standard? if so, you might be restricted with the power you make.
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2739695
Don't stress mate.
You should expect any were from 230-250rwkw depending on what boost you run
as 250 give or take is maxing out your stock inectors.
As long as it doesn't lean out badly or run too rich you should be safe.
However, this depends on the tuner's experience.
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2739830
Just pump boost into it until you either get valve float, no gain, or run out of fuel.
I think the limiting factor in your setup is the walbro intank pump. You may find that your injectors are maxing out earlier than expected if it isn't up to the task.
Stock valve springs and lifters will likely stop the fun at about 20psi anyway.
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2740539
20 will be safe on stock internals.
Just dont expect anything super brilliant in terms of response with a t04e, around 5000rpm before yo'll really see much of a song start :)
It'll make good power, just take a while to do it
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2740980
you are absolutely right R31Nismoid, the song starts :) at around 5000rpm and this is the lag that makes me think of going to a better turbo even before i dyno it. thanks mate
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741042
looking at your mods and the condition of your engine
with cams, it should see full boost earlier then it would, with just standard ones.
And i have just a r33 plain bearing hiflow on mine set on 15psi pretty much doin 230rwkw. with pretty much the same mods as you except for cams. My turbo is set on 18psi, but i have been restricted to 15psi because of the standard actuator bleedin off to early.
Having a t04e turbo, ( i haven't had one before, but have seen specs.)
i would be hoping to equal 270rwkw and or higher sittin on 1bar boost.
Just depends how good your tuner is, and what condition all your mods and turbo is in.
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741063
on an RB20, there is no way its going to make 270rwkw @ 1bar
I had the old GTS-R turbo on the RB25 which was a t04e front and a hybrid T3 int gated rear... and it came on 13psi @ 4200rpm/220rwkw on the RB25
Check FATGTS-R's results with his version, its taking a bit more than 1 bar to mash out 270rwkw
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741221
I recon do yourself a favour and get a better fuelpump, no mention is the walbro direct connection to battery loop or using the standard fuel power source, your setbacks are the pump and turbo choice, let alone its all been said above, ove noticed lowered compression ratio with the head gasket so you should be able to pump in a bit pending on what your turbo allows you to do im guessing? Goodluck on your endevours and keep us posted
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741259
well thats fair enough on a rb20, but he has stated its a rb25det series 2
with cams and all the fuel supporting mods.
As i dont have a t04e, i wouldnt know, but looking at my car and he has a bigger turbo, ball bearing??
Maybe not at 1 bar but hopefully it shouldnt be too far off
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741639
whops, RB25, didnt read that line :happy:
But yeah, i made 220rwkw @ 13psi with a t04e/hybrid T3 rear... so i doubt its going to be much more different, maybe 20rwkw higher with a different rear. But no more.
If you make 335rwkw, i'll be surprised mate.
The turbo will be working its guts out, and my guess @ somewhere above 24psi will be needed to get there
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741948
so mates do you suggest setting the boost on 20psi all the time and that will be safe with no harm to engine at all? Anybody got settings for greddy profec-B spec II for 20psi (gain, set gain, warning...etc) i find it confusing sometimes
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2747202
Look, its your tuners call.
Some people run into valve float issues when boost gets higher etc.
IMO, ask the tuner to run as much boost as possible.
If the tune is decent and there are no issues. Then really there should be no issue.
If knock doesnt go about 25-30, then it should be fine.
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2747564
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
