Hi everybody,
I am planning to take my R32 to its first run on dyno this coming thusrday, and i am seeking your advices and any tip that helps...like should I raise boost when on dyno or jsut stick to 1 bar?>(tuner's advice)
here are the major mods:
RB25DET Series 2
Garret T04E turbo
3" FMIC
Custom 3" air intake piping
BOV
Turbonetics Evolution wastegate
custom 3" downpipe
Tomie cams (270/8.8 both)
HKS metal head gasket 1.2mm
Walbro 255 in-tank fuel pump
HKS 555cc injectors
SARD standard fuel pressure regulator
Centerforce single plate clutch
HKS N1 muffler with custom 3" exhaust pipes
Greddy Profec-B Spec II
Apexi Power FC
Edited by Light
https://www.sau.com.au/forums/topic/146761-dyno-first-run/
your tuner will tune the car to its potential. so if he thinks it can take more than 1 bar then he'll turn it up.
from the sounds of your setup, it will depend on the maximum allowable flow of your turbo.
also, you havent listed an AFM in your list. is it still standard? if so, you might be restricted with the power you make.
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2739695
Don't stress mate.
You should expect any were from 230-250rwkw depending on what boost you run
as 250 give or take is maxing out your stock inectors.
As long as it doesn't lean out badly or run too rich you should be safe.
However, this depends on the tuner's experience.
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2739830
Just pump boost into it until you either get valve float, no gain, or run out of fuel.
I think the limiting factor in your setup is the walbro intank pump. You may find that your injectors are maxing out earlier than expected if it isn't up to the task.
Stock valve springs and lifters will likely stop the fun at about 20psi anyway.
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2740539
20 will be safe on stock internals.
Just dont expect anything super brilliant in terms of response with a t04e, around 5000rpm before yo'll really see much of a song start :)
It'll make good power, just take a while to do it
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2740980
  Quote
you are absolutely right R31Nismoid, the song starts :) at around 5000rpm and this is the lag that makes me think of going to a better turbo even before i dyno it. thanks mate
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741042
looking at your mods and the condition of your engine
with cams, it should see full boost earlier then it would, with just standard ones.
And i have just a r33 plain bearing hiflow on mine set on 15psi pretty much doin 230rwkw. with pretty much the same mods as you except for cams. My turbo is set on 18psi, but i have been restricted to 15psi because of the standard actuator bleedin off to early.
Having a t04e turbo, ( i haven't had one before, but have seen specs.)
i would be hoping to equal 270rwkw and or higher sittin on 1bar boost.
Just depends how good your tuner is, and what condition all your mods and turbo is in.
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741063
on an RB20, there is no way its going to make 270rwkw @ 1bar
I had the old GTS-R turbo on the RB25 which was a t04e front and a hybrid T3 int gated rear... and it came on 13psi @ 4200rpm/220rwkw on the RB25
Check FATGTS-R's results with his version, its taking a bit more than 1 bar to mash out 270rwkw
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741221
I recon do yourself a favour and get a better fuelpump, no mention is the walbro direct connection to battery loop or using the standard fuel power source, your setbacks are the pump and turbo choice, let alone its all been said above, ove noticed lowered compression ratio with the head gasket so you should be able to pump in a bit pending on what your turbo allows you to do im guessing? Goodluck on your endevours and keep us posted
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741259
well thats fair enough on a rb20, but he has stated its a rb25det series 2
with cams and all the fuel supporting mods.
As i dont have a t04e, i wouldnt know, but looking at my car and he has a bigger turbo, ball bearing??
Maybe not at 1 bar but hopefully it shouldnt be too far off
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741639
whops, RB25, didnt read that line :happy:
But yeah, i made 220rwkw @ 13psi with a t04e/hybrid T3 rear... so i doubt its going to be much more different, maybe 20rwkw higher with a different rear. But no more.
If you make 335rwkw, i'll be surprised mate.
The turbo will be working its guts out, and my guess @ somewhere above 24psi will be needed to get there
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2741948
so mates do you suggest setting the boost on 20psi all the time and that will be safe with no harm to engine at all? Anybody got settings for greddy profec-B spec II for 20psi (gain, set gain, warning...etc) i find it confusing sometimes
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2747202
Look, its your tuners call.
Some people run into valve float issues when boost gets higher etc.
IMO, ask the tuner to run as much boost as possible.
If the tune is decent and there are no issues. Then really there should be no issue.
If knock doesnt go about 25-30, then it should be fine.
https://www.sau.com.au/forums/topic/146761-dyno-first-run/#findComment-2747564
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
