hey, just put splitfires and NGK iridium plugs into my skyline r32 gtst which has solved my missfire problems instantly :laugh:
but my next question is about the boost the car is running.
there is an aftermarket boost gauge installed on my car (previous owner) and when im flat chat accelerating in 5th the needle goes up to about 17psi.... could this be misreading?
i havent got an aftermarket boost controller so im interested to know how the car limits its boost levels?
not real cluey on this sorta detail unfortunately, any help appreciated!
mods include: FMIC, Cat Back 3" exhaust, otherwise stock
https://www.sau.com.au/forums/topic/147229-standard-r32-boost/
Boost is regulated via the spring in the wastegate actuator. R32 GTSt's run 10psi normally but by freeing up flow in other areas (exhaust) you can gain small increases in boost.
Does it level out at 17psi? or is that all you let it get to before you freak out and shut it down?
i will check it again 2day, but off the top of my head the VAC is at about 20 on idle....
its only got the stock BOV on it (no aftermarket bleed valve), i will check bout the levelling out but yes it is a bit scary watchin the needle just keep rising.....wood be fine if i knew that the components could handle it, but like u sed it isnt exactly safe
will check back soon after lookin at a few more things 2day
Maybe check the wastegate vacuum hoses before you drive it again.. if it is rising past 17psi I don't think you actually wan't to let it do that to confirm it is a wastegate hose fallen off.. much healthier for your engine to check it first :dry:
By bleed valve I meant boost controller not BOV.
lol, well i drove it round today and tried not to push it, but i did give it a boot to check and it only goes as high as 17psi n peaks, VAC is 20 at idle....
will check the vacuum hoses n that 2moro but other than that what else could i check?
it doesnt have an aftermarket boost controller, should i maybe invest in one of these to limit the boost level?
thanx for all ur help so far guys
Bleed valve can only increase boost, can't decrease it. Sounds like you have a crack/split in your waste gate vac line acting the same way a bleed valve does. If its even remotely perished replaced it, if it gets any bigger itll boost infinitely and POP goes your motor.
What is odd though is normally the ECU will just fuel cut or the car would start misfiring badly at that sort of pressure, I really would not drive it until you have sorted the issue.
Pretty sure standard boost on an RB20DET is 10psi. Anyone want to back me up?:)
i will back you up. people look at the stock boost gauge and this yeah 7psi. the rb20 actuator doesnt open below 10psi. if you look at the gauge closely the gauge isnt measured in PSI. the gauge is in bar. 0.7bar =10.152642psi
fin... :)
Well on my aftermarket guage I get 9-10psi with only a cat back exhaust and a split dump (for some stupid reason it still has a stock front pipe and stock cat) so I would imagine it not being much more freed up than it was standard.
Have since put a Turbotech manual boost controller in and think I was hitting R&R around 14psi. I've dropped it back to 11.5-12psi and it seems to go better in the top end, doesn't come on boost as harsh though which was fun but then it didn't really go anywhere.
stock boost on a rb20 is def 10 psi!!! that is why when people buy rb25 turbos they put the actulator off the rb20 turbo to run 10 psi... def sounds like u have a split in the hose or something like that... or a faulty guage.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
