hey, just put splitfires and NGK iridium plugs into my skyline r32 gtst which has solved my missfire problems instantly :laugh:
but my next question is about the boost the car is running.
there is an aftermarket boost gauge installed on my car (previous owner) and when im flat chat accelerating in 5th the needle goes up to about 17psi.... could this be misreading?
i havent got an aftermarket boost controller so im interested to know how the car limits its boost levels?
not real cluey on this sorta detail unfortunately, any help appreciated!
mods include: FMIC, Cat Back 3" exhaust, otherwise stock
https://www.sau.com.au/forums/topic/147229-standard-r32-boost/
Boost is regulated via the spring in the wastegate actuator. R32 GTSt's run 10psi normally but by freeing up flow in other areas (exhaust) you can gain small increases in boost.
Does it level out at 17psi? or is that all you let it get to before you freak out and shut it down?
i will check it again 2day, but off the top of my head the VAC is at about 20 on idle....
its only got the stock BOV on it (no aftermarket bleed valve), i will check bout the levelling out but yes it is a bit scary watchin the needle just keep rising.....wood be fine if i knew that the components could handle it, but like u sed it isnt exactly safe
will check back soon after lookin at a few more things 2day
Maybe check the wastegate vacuum hoses before you drive it again.. if it is rising past 17psi I don't think you actually wan't to let it do that to confirm it is a wastegate hose fallen off.. much healthier for your engine to check it first :dry:
By bleed valve I meant boost controller not BOV.
lol, well i drove it round today and tried not to push it, but i did give it a boot to check and it only goes as high as 17psi n peaks, VAC is 20 at idle....
will check the vacuum hoses n that 2moro but other than that what else could i check?
it doesnt have an aftermarket boost controller, should i maybe invest in one of these to limit the boost level?
thanx for all ur help so far guys
Bleed valve can only increase boost, can't decrease it. Sounds like you have a crack/split in your waste gate vac line acting the same way a bleed valve does. If its even remotely perished replaced it, if it gets any bigger itll boost infinitely and POP goes your motor.
What is odd though is normally the ECU will just fuel cut or the car would start misfiring badly at that sort of pressure, I really would not drive it until you have sorted the issue.
Pretty sure standard boost on an RB20DET is 10psi. Anyone want to back me up?:)
i will back you up. people look at the stock boost gauge and this yeah 7psi. the rb20 actuator doesnt open below 10psi. if you look at the gauge closely the gauge isnt measured in PSI. the gauge is in bar. 0.7bar =10.152642psi
fin... :)
Well on my aftermarket guage I get 9-10psi with only a cat back exhaust and a split dump (for some stupid reason it still has a stock front pipe and stock cat) so I would imagine it not being much more freed up than it was standard.
Have since put a Turbotech manual boost controller in and think I was hitting R&R around 14psi. I've dropped it back to 11.5-12psi and it seems to go better in the top end, doesn't come on boost as harsh though which was fun but then it didn't really go anywhere.
stock boost on a rb20 is def 10 psi!!! that is why when people buy rb25 turbos they put the actulator off the rb20 turbo to run 10 psi... def sounds like u have a split in the hose or something like that... or a faulty guage.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
