Ah who told you that!! I think the "clips: you may be refering to are the syncro Paws and there is stuff all you can do with 4th gear without stripping the box to nothing as 4th gear IS the input shaft.
2 different places that have put them back in without stripping it!
  • Replies 56
do yourself a faour and grab a copy of the workshop manual. Even for an RB20 or CAa8 etc, have a look at the exploded view of almost any nissan transmission and explain which clips they are putting back in each time??
Im curious cause I have been doing these boxes for years and not one of the syncro's is servicable or even accessable without removing the extension housing and bellhousing then pulling it down.
I know anyone who knows anything about transmissions will agree with me as well.
today i purchased "royal purple max gear" gear oil for my car today, apparently its better than the redline products... im going to put this in sometime this week if i get a chance. i will update the results once i have put the oil into the gear box
well i put the oil in today... first thing i notice when i drained the oil from the gearbox was that it was a bit old n dirty, the drain plug had a few shavings on it but nothing to worry about. it took 3 litres of oil to fill up and after i took it for a test run the 1st thing that i notice was the smoothness of changing gears even at hig revs... so i think ive fix my problem and i hope this helps someone else. also keep in mind my car has only done 65,000kms
How much was the Max gear oil/how many litres?
What weight?
there is no chance in hell they can without stripping it, and without access to the right tools you arent gonna get very far not to mention all the clearances you need to take into consideration. get em wrong and at best you will have a clunky ass box... or at worst a box with stripped gears.
My theory is that the r33 box and gearset is very strong. Like everything else though (and the way the skylines get driven), the synchros wear out.
My theory is that the synchros are just inadequate. My car was in near mint condition when I bought it and only 34,000km. With the original oil in it, 4th and 5th would grind. With Motul full synth in, 5th still grinds. They're just weak synchros!! Wear has nothing to do with it, by all accounts my car was cherished when it lived in Japan and it still has the problem.
They are not weak syncros! The double syncro in the Nissan box is amongst the best there is!
Wear has EVERYTHING to do with the result you feel. A weak syncro will break not cause crunching.
Do any of you know exactly what part of a syncro actually wears for it to begin crunching???
Or even how a syncro in fact works?? A better understanding of the component would help you come to terms with what can wear.
For instance you can baby a car around for 50000Km's BUT rest your hand on the gear stick all the time and wear out a selector ring. INSTANT crunching! and you have not even flogged the vehicle yet! I little pressure on the stick equates to a load on the selector fork and ring hence premature wear.
Dont be blaming the syncro's inside a gearbox you dont fully understand
If you have ever had a box apart thats broken a baulk ring you will know how it was to select gears, next to impossible infact.
I apologise I probably wasn't clear enough with what I was getting at.
Of course you'd have to pull the extension and bellhousing off! What I mean was stripping one of the shafts?
Edited by PJ.
Hey, I'm currently smack-bang in the middle of a 'box rooting . . . . :blush: (Oh how I wish it was as good as that sounds)
SAU Vic thread on My rooted Gearbox
It gets dropped off for a strip today, I'll be updating my Vic thread on what the damage is, literally and financially. :)
yeh you have to strip the shafts so you can seperate them from one another, and remove them from the sandwich plate, thats how i had to do it with my MX7 im guessing the r33 box is identical.
Yes your right, to access anything syncro related 1st to 4th you have to separate the shafts from the syncros. Some boxes are designed to be "modualar" such as the PAR (evil box) these boxes you can remove the gears via circlips from the front of the box and there is no need to strip from the sandwich plate. However there is no OEM nissan boxes like this.
Perhaps yours is not a factory gear set if thats the case??
R34 Gtt box with OS Giken Cross mission gearset 1st, 2nd, 3rd. They still use standard syncros though.
Should be able to get these clips in by pulling back the syncro hub, and not have to strip the box excluding bellousing etc...
Edited by PJ.
There is your answer. You cant get the syncro paws back in without taking the hub right off because there are offset springs inside the assembly that need to be located properly.
I think you will find the gear set your using is a modular design and they are pulling the front gear off the lay shaft, removing the input shaft (4th gear) and pulling the selector hub almost all the way off and putting the paws back in.
However there is something seriously wrong if you keep throwing them out. the only way for that to happen is if the hub is moving to far and allowing them to come free.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
