already done :)
don't forget you got a hiflow-cat and front/dump with that too :laugh:
No that was just the catback... batmbl dump cost me $400 cat cost me $300. + around 200 for fitting :)
complete exhaust cost me $1700.
Edited by CEF11E
I don't think you can purchase Ti donuts and other 45/90 degree pipes, thats why they "section" it where bends are needed, with lots of little sections cut and shut.
Rofl, i wonder if it was done like that with stainless to fool people... how awful :)
Top Secrete and others use the same technique with Ti on their engine bay piping, and just then, when looking for a picture, I noticed >> http://www.topsecretjpn.com/r34drag5.jpg
I rem that car using piping that was discolored like normal Ti at a Jp AutoSaloon.. Now it's yellow *ponders*
:laugh:
PS: Foznice - Ti is completely non-magnetic, test with a magnet for the truth....
- M
Edited by GeeTR
give me that exhaust, Rich!
hehe, no can do. :) love to help though. i'm getting a veilside tear drop titanium for my thing. that arc one i tried to buy but missed out :laugh:
where would get a titanium cat back system from and how much u looking say for r32 gtr
for a decent titanium cat back for 32 GTR it's approx $2-2.5K. i haven't seen any really good local ones. there are plenty of nice japanese ones though.
even a decent set of front pipes like these is around $1K
really? you must have got the stainless one then?
I remember rrrage got the full mild system for $700
Yep I got a full stainless system turboback. Nothing wrong with mild steel, just stainless was only around $100 extra.
It still looks like a really nice system it's worth what you paid for it.
hehe, no can do. :) love to help though. i'm getting a veilside tear drop titanium for my thing. that arc one i tried to buy but missed out :)
i do like the sectioned droopy exhausts... but a twin Ti system would be tops!
A friend of mine used to build Ti racing pushbikes (until china pushies), to look at unheated it is very similar to stainless but has a greyer/silvery hue, he welded it in a vacuum chamber with tig, he filled it with argon then sucked it all out to form a non O2 enviroment.
I assume it's all in the fabrication time and cost... Ti itself isn't that expensive as a material in such small quantities, it's the sectioning and 'lobstering' the piping that is time consuming and must be damn expensive to pay a quality welder in Japan!
I think it depends on the workshop equipment.
Recently saw some Corvette mufflers at the local exhaust shop. They'd been replaced with an Aus built product. (To meet ADR I presume)
I could lift each muffler/pipe unit with 2 fingers and yet each one was the size of 4-4L paint tins. Pipework was very complicated and beautifully bent, not sectioned.
They weren't available for sale unfortunately.
yep you're right - these would be a bit cheaper to make becuase they've been mandrel bent.
when you're sectioning like baron posted earlier in this thread, it is alot of labour to cut, weld, finish etc nicely.
i would love a Ti exhaust!
Please don't quote me on this, but my understanding is that you cannot bend (mandrel or otherwise) titanium pipe sections the same way you can with stainless steel for the following reasons:
It is not very ductile.
It has a low modulous of elasticity (ie it will spring back after forming)
Has a tendency to gall much more than stainless.
If you add to this the requirement for fastidious cleanliness when working with the stuff, you can see why it is so damn expensive.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
