Hey all,
Just a quick question, does anyone know what day the HSV Owners club is going to PI this weekend, if there is one?? I vaguely remember there being sprints on this weekend, but I need confirmation. Pretty sure it was the 16th...
Cheers
Dane
https://www.sau.com.au/forums/topic/147438-hsv-sprints-at-pi/
Thanks guys.
I may be a touch confused, but I know that there was a HSV day on this month at some point at PI, so I'll keep digging.
I don't want to enter anything Bec, just want to take a look see :)
EDIT: Way off :devil: It was in October
Supp Regs, etc
I guess theres a possibility some people have pulled out.
Could always give them a call and see if you are interested.
Last time i spoke to Neil Choi there was 20 people of the waiting list :):P
Regards
Andrew
Yes, explain.
I've got one of the quietest GTRs around and I was flagged in the first session for noise. Apparently my car was 83db and the limit for the track was 75db.
Beno has tweaked some magic into the car. I was litterally just warming up and had traffic holding me up and I was completely surprised to see the 1.45 times. I'd say now that 1.43s or even better if I get brave are possible with the car the way it is.
I went out in the second session and got flagged instantly. Home time after that.
BUGGER !!!
Yes, explain.
BUGGER !!!
I got pinged for 81 at the MSCA day Aaron - the EPA guy goes after lunch so just short shift and wait till the arvo sessions.
Soooooo......how is the stroker kit :(
I have to ask, is still fun going that quick? It woudl scare the shit out of me. Top work
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
