Just noticed,
My rb25det oil pressure dropped, from the *4 Mark, down to the first line,
normally always sitted at the 4 mark, now its sitting at the first line *unmarked line*,
No oil leaks, I could find, some slight oil residue comming from rocker covers.
Oil level is fine, But have noticed turbo making slight werring or whining noice when boosting hard now.
Thinking that My oil pump could be showing its age..
anyone agreee? disagree?.
https://www.sau.com.au/forums/topic/147504-oil-pressure/
firstly i'd get that seepage out of the rocker covers fixed.
and its more than likely to be your turbo rather than your oil pump. a blown oil seal in your turbo will cause the lower oil pressure.
check for oil in your intercooler piping at the lowest point then report back.
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753081
Pulled off front pipe (lowest pipe) , found small trace of oil residue, when i whipe my finger on bottom of the inside of the pipe,
I would assume this is normal?
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753362
same pressure cruising or at idle. or not much change noticable.
oi is nulon high tech fast flowing 10-40w, for import turbos etc.
been using same oil since i got it.
havnt checked with full throttle yet.
Edited by silverbulletR33
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753926
im asking for the actual pressures.
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753937
OK cruising at 110, and giving it a bit, went just over the *4 mark.
thought it Might possibiliy have something to do with the viscosity of the oil, so i did a oil and filter change, and now back to normal.
now sitting on 4-6
So, Nulon Hi-Tech, fast flowing stuff, which is 10-40w, after 3900kms looses some viscosity which make the drop in oil pressure.
:) maybe ill try new oil next time.
theres gotta be something wrong for it to loose its viscosity only after that muc kms? or is this the norm?
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2772147
Sounds like the oil sender/guage is faulty.
Best bet would be to use a second guage to confirm that to make sure that it's not a major issue.
I don't think it's the oil pump, because if the oil pump was going, the oil pressure would be low, not high.
on idle, it should be around 2. If it's up at 4, that's reading twice as much, so i'd think it's the guage/sender
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2772779
I don't think there's anything wrong with the oil. For the pressure to double, that would have to be pretty majorly wrong.
That nulon oil is good stuff.
It could be anything mate. tempamental sensor? Or guage a bit lazy for a moment.
Just see if it happens again with this lot of oil.
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2772782
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
