Does any sydney-siders know where I can buy a lock nut for my nismo rims. I lost the dam thing and need to change my pads!!!
thanks in advance,
andrew
If you get stuck, you can belt a similar sized socket on there and undo the lock nuts. But doing this will ruin the socket and more than likely the lock nuts.
By the sounds of it you are screwed anyways, so you might just need to do this and buy a new set of lock nuts.
Go to a mechanic or tyre shop, get them to bang a socket over the locknut and give it some love with a rattle gun. You may have to try a few places. I can recommend Jax tyres in blacktown, one of the guys there got my locknuts off without even damaging the socket. champion.
If you can find someone with the same brand of lock nuts, in most cases they're compatible. I've had a mate lose his RAYS lock nut, and borrowed mine.
Otherwise, hammering a socket onto the lock nut and taking them off is the other option. With no key the lock nuts are useless anyway.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
