D....de..def...defected (ho Ho Merry Christmas)
  • Replies 55
This is the biggest worry.
You will get hardly anything aftermarket through once that is done.
Pretty much 100% stock as a rock. Exhausts won't pass, no boost increase, pods and intercoolers might not even get through.
Definitely a worry. Those with rebuilt motors will have to ensure they keep all the quench standard as opening up the quench has emissions go to shit.
Thicker headgaskets.. poor emissions also. :P
Sorry to hear Darren,
if you need any other parts, post it up and I might have some lying around
I have a complete stock diff assembly at home also, but this may be needed as my 1.5way is showing signs of wear
thanks. Looks like i only really need an rb20 afm - or a r33 series 1 green sticker one
Im wondering if they would let my Bilsteins through??
I can get em set to std height via the circlip. Manta racing will machine a groove to put em up to std height for me.
Just gunna paint em black and set then to std height, and hope for the best :laugh:
Edited by Bl4cK32
suspension requires a vis check
shite, u learn something everyday!
When i got done about 1.5yrs ago the copper told me that to go to regency you needed to get done for something emission related or more than 3 things!
like when i got done............for an out of date LPG tank
got it tested, could hav basically walked into a cop shop with the paperwork and got it cleared, but got sent for VIS instead :ninja:
The nice policeman politely showed me on the front of one of his books the list of thigs which either require a VIS inspection, or just a police station clearance.
Suspension shows a vis check.
Then he tells me "If it was an oil leak, that only requires a trip to the police station. See here".
The funny part was he was looking for what height the car is supposed to be std. He then sees r32 GTR and says "Yes, see it says here 275mm..." I then proceed to show him in his book that mine is listed as a r32 GTST and yes, the height is supposed to be 360mm (I cant remember now though for some reason...too much trauma) not the 275 he was going to measure.
Edited by Bl4cK32
so how much too low would u hav been at the 275mm height?
or wouldnt it hav been too low?
im at 330mm in the front, 350mm in the rear.
@ the correct height, im 30mm too low in the front, and 10mm to low in the rear.
@ 375mm (if this was measured) id obviously be 45mm too low in the front, and 25mm in the rear.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
