Hello,
I needed a new (used) car and came across this ad:
R33
(Yes, I'm in the UK)
I liked the car, because this one is not modified and has not any embarrassing mods or spoilers.
The price is 12,500 AUD.
Though the price sounded a bit steep to me I had a look at the car.
Had A Look At The Car
In reality it didn't look that gorgeous anymore, but I still liked it.
I did some checks on the car, and followed an advice I got to verify the year:
The year of manufacture can be found by looking at the front seatbelts, near the floor mounting point. There is a fabric tag with the seatbelt specifications and the year of manufacture sewn onto the webbing.
So I checked the tag and it said 1993! ;)
I pointed this out to the seller, and he said that the seatbelt might have been replaced ..
I think that's quite a far fetched story, but are there any things apart from the tag to tell the year?
I checked many Skyline pictures, and all with the year 95 seem to have an airbag.
There's a number on the firewall where the engine sits and it says:
ECR33-002864
If this is some kind of serial number, it sounds pretty low to me and would support the 1993 tag year.
Hmmmmm .....
Is there any check I can do on the number?
I still like the car, and the engine made a good impression on me.
I'm a complete beginner with Skylines and any help is highly appreciated.
Thanks for the help!
Greetings from London!
https://www.sau.com.au/forums/topic/147634-how-to-tell-the-year-of-a-r33/
Car is a '93 or '94 model ;)
- Seat belts are manufactured by another business, so they can be done in advance.
- The engine has the coil igniter modual, on the top, at the rear (near the firewall), which only came out in '93 or '94 cars.
- Has the S1 rear spoiler
- No airbag
"The price is 12,500 AUD.
Though the price sounded a bit steep to me"
Hi,
I would have thought $12500 for an R33 with 69000km on the clock, was little on the too good to be true end of the scale if anything...
Damien
Edited by ShylineR33
Hi,
Damien
No, it represents the upper limit for such a car in the UK and I'd only pay the amount for a 95 in mint condition.
As for the milage you should consider if such a low milage is realistic for an 11 year old car.
The car in the link (true 95) below is at 13,000 AUD and also at the top range of prices.
Besides note that this is not a GTR!
GTRs is what people want, so the price is higher.
Cheers
Edited by Torques
- No airbag
:D
Thanks, I agree ... the seat belt could be made in advance ... but 2 years?
So much harder evidence seems to be the spoiler / airbag / coils.
What does S1 mean? And when came the 'new' spoiler exactly?
Can I do any research regarding the number on the firewall?
If you look at this one, it seems to be a true 95 model and I'd pay the price for it.
True 95
True 95
that one looks like a S1.5 - S1 front with S2 wing and the clear skyline boot garnish
the higher wing came on the S2 models, and on the S1.5 models
S1 is series 1 - info can be found here
S1.5 is series 1.5 - info can be found here , this is basically a S1 with the S2 wing and engine.
S2 is series 2 - info can be found here
more info on model differences can be found here
it is mainly cosmetic changes and standard options, there is other things like the coil igniter module as noted above
you can post the VIN number (number on firewall) in these threads and someone with the Nissan FAST program will check it out for you
http://www.skylinesaustralia.com/forums/in...howtopic=133729
http://www.skylinesaustralia.com/forums/in...howtopic=128496
yeah it looks like a 93 - rear spoiler and steering wheel - but thats how i look at it
what is it bout the steering wheel that differentiates the models? just curious
EDIT: ok realised for myself. its the airbag right?
Edited by Basti
Good morning from the UK!
Wow ... I woke up this morning and was wondering whether there is any reply at all.
:P
Thank you so much for all the information, this is just great!
I knew from the start that the car didn't feel like a 95 model, but the seller was asking the 1995 price for it.
He stressed many times that this is a 95 model...
As for the airbag I read in a wiki that all 96 models have the airbag as standard.
I think with the VIN number I really can nail the seller down on the year.
(Unless he argues that this has been replaced as well)
Cheers!
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
