Hey There
after a power fc for an r33 gtst series 1 94 model prefer still new but will also buy second hand aslong as its in good condition and removed properly. Let me know what you have and how much your after cheers iLEC.
Edited by iLEC
https://www.sau.com.au/forums/topic/147783-apexi-power-fc/
damm got excited when i seen the replys lol yeah it sux i knew i shoulda got them at the group buy for $950 delivered now i think im just gona have to fork out $1300 + :nyaanyaa:
https://www.sau.com.au/forums/topic/147783-apexi-power-fc/#findComment-2775096
im looking for a power fc as well but looks like we're screwd lol....thinking about just getting a stock one and get it fine tuned (coz got a mines tuned one now that is pretty aggressive as it is...)
https://www.sau.com.au/forums/topic/147783-apexi-power-fc/#findComment-2780968
If you guys can get at least 5 definates for the R33 GTST Power FC then I can supply them for around $1150. We get back to work on the 2nd so will find out exact price for you then.
https://www.sau.com.au/forums/topic/147783-apexi-power-fc/#findComment-2781423
Ok to get things moving 5 people
iLEC - R33 GTS-T Series 1 94 model
bloodsword27 - ?
LBR33 - ?
please post hear to confirm weather your in or not on the possible group buy :happy:
https://www.sau.com.au/forums/topic/147783-apexi-power-fc/#findComment-2781608
iLEC - Definate
LBR33 - Definate
ok we need 3 more people that want a power fc for r33 gtst to get the group buy price :)
Edited by iLEC
https://www.sau.com.au/forums/topic/147783-apexi-power-fc/#findComment-2782811
Before you do you can pay to become a business trader.
https://www.sau.com.au/forums/topic/147783-apexi-power-fc/#findComment-2784604
Guest
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
