2006 SAU Vic Club Award Winners
Thanks to everyone who sent in nominations for our awards - and a huge congratulations to the winners!
1. Thread of the Year
Nom 1 = The SAU Stickers Thread
Nom 2 = James vs Troy
Winner = Al's Haunted House!
* click here to download the Ghostbusters Theme song :ninja:
2. Photoshop of the Year
Nom 1 = The Drag Lada
Nom 2 = The Drag Juz
Nom 3 = The Dutton Team
Winner = Age's flapping James!
3. Mines Datsun 'she'll buff right out' trophy
Nom 1 = Pete's stupid radiator
Nom 2 = Jackie and her pole
Winner = Will and his 'kangaroo'!
* note, not linking to pix for these on purpose :rofl:
4. Motorsport Junkie
Nom 1 = Gary & Alycia Matthews
Nom 2 = Aaron Panozza
Winner = MissJuz!
5. Most improved car
Nom 1 = Ferni's Team Purple R33 GT-R
Nom 2 = Roy's mighty Silver Bullet R32 GTSt
Winner = Rowdy's K-Mart Racing R32 GT-R
https://www.sau.com.au/forums/topic/148233-2006-sau-vic-club-awards/
6. Not a Skyline (but we still love you)
Nom 1 = Justine's S15 200SX
Nom 2 = Scott's Super TX5 Telstar (RIP)
Winner = Dane's widebody 180SX
7. Photo of the Year
Nom 1 = Ferni's flaming brakes - Ryan
Nom 2 = Anything Joel took :ninja:
Nom 3 = The 'other' Snowy
Winner = Storm at DECA by Dark
8. Troy S. Brisby Club Social Award
Nom 1 = Sarah B
Nom 2 = Gareth 'Riverdance' Evans
Winner = Steve McQueen!
9. Presiden't Award
Jack Blanas - The Stig!
10. Club Member of the Year
Nom 1 = Mavrick
Nom 2 = Chris and Min
Bec Pretty
Thanks for the votes to all that gave them. Sorry Ferni.
Really what needs an award is the special thanks that Al gave (I'm to shy but would have loved to have given it) to all of the people behind the scenes at SAU that we know and some of us don't that but put on such fabulous events that nobody could fault. You are the people that let most of us still have a licence and we get to meet a similar crowd with a similar age group with great personalities that couldn't be found anywhere else. Give yourselves a pat on the back from me expecially!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
