  • Replies 6k
Posted Images
Stuff having a soft top, only takes 1 sharp object from someone to cut and you have to fix($$$$$$$$)
i try not to think that anyone who looks at my car - or any other car for that fact, is a thief or potential thief.
a good british roadster is what should be bought if thinking softtop ;D
i have to admit, going for a hammer in michael capella's mx5 was so much fun to windy point
on a side note (which is what wasteland is all abotu lol) UPGARDE TIME IN LESS THAN A WEEK, YAY!
yeah thats such a negative shitty way to think, and you'll become so badly paranoid you wont even wanna drive your car anywhere anymore, wtf is the point of having a skyline if its gonna sit in your garage all the time where nobody can see it :D
ok maybe that was written out wrong. i was trying to say nobody thinks that someone is going to target their car just b/c they have a soft top - if that made sense. unfortunately, my car is in the garage where nobody can see it - not intentionally either.
it's good to be paranoid about your car to some extent. If every single person put a good alarm with immobilisation points in their car it would cripple the stolen car racket and reduce everyones insurance premiums. This would of course be a very good thing.
Especially since you have a vehicle pager system Sam and Duc - it's the only way to go imho. I am putting the same alarm as you guys in my R34 before I put it on the road. It should be the law imho.
the pager system makes leaving your car parked anywhere a bit less nerve-racking. so when is the 34 all ready to go? :D
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
