  • Replies 6k
Posted Images
ugh. coz my dad is italian... and both hes parents migrated to here..... and then had him here. so he is full blooded italian... was jst born here as opposed to in italy.
hence giving me half wog...
um is italian wog?? it's a serious question
(this could be one of my blonde moments)
R31turbo,
I'm doing DB2... if its anything like db1, db2 will suck. :P
No cp2a for me.. Already done, DN. :P
I've got a couple little bits to tidy up then I'm all done.
I've seen you (didn't know it was you then) in the past around car park 2. :(
Pokie...
Blood lines pokie, blood lines. :)
yes Italian is wog.. Some also consider european to be wog.
ha db1 wasnt too bad i got credit but db2 is harder ... programming related sql cmbined with c -- i did it last yr and left a comma orsumthing in my program and it stuffed it all up as she just runs it doesnt look at code so i dropped out. as for cp2a i did cp2b and passed it and i have cp2a left!
Edited by r31turbo
having wog in you. does not make you a non-australian unless you migrated here and are not an australian citizen
But not following AFL and prefering the soccer makes you a WOG :lol: :D
im half wog, i think every one in australia has i little in them :)
We've all heard that about wogs, visit the loo and come back with a little bit of wog in you :lol: :lol: :lol:
Edited by 4door_Sleeper
We've all head that about wogs, visit the loo and come back with a little bit of wog in you :lol: :lol: :lol:
Damn I hate that... Straight over my head, maybe i'm tired. lol
What ever it is you must be thinking of the southerner's and or the sicilians. heh :(
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
