  • Replies 6k
Posted Images
I will be heading to ballarat in 2 weeks for a 21st (free alcomahol!! :D )
...... Hope Victorian police aren't as bad as I have heard they are!
DON'T SHOOT!!
what u comin my way for? be warned that it will rain or be at least cold whilst here in melbz. we have retarded weather times 10
goin up there for a cruise with SA PGA(Pulsar Group of Australia)
stayin there over the easter long weekend.
rain argh, i seriously gotta get me some winter pajamies ehehe.
i'm hoping i don't get too homesick, i got homesick the other week
just thinkin about it LOL :D
lol would not have a clue sorry. i dunno where most hotels are... dont really have a need to since i dont needa stay at em.
but generally most of the hotels are located central to the city.
sounds like a hotel in carlton ( which is like 5 mins from the city if that ) from memory
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
