sifnt hear it in real life
come out on a cruise :O
ive been on heaps :D nut not lately when you guys have been arround
add me :teehee:
MSN [email protected]
Shall we do one Next friday? 29th dec?
last cruise for the year
Need a big turn out, last 2-3 has been very slack, most we got was 5 (with a WRX)
:sorcerer:
code you email addy so spybots and webcrawlers dont snatch your email do like
andyy5k at Hotmail
  • Replies 6k
Posted Images
add me :teehee:
:sorcerer:
Yeah next friday, I'd be keen for sure should be able to get a few more ppls out and about
im not really an active member here but i was wondering if somebody could help me source a r32 gts-t/gtr rear left reverse light? i was driving up my mates driveway and tapped the back of his car
Edited by wyzokie
Try niswreck or something.
Look in the for sale section here. There are always skylines that have been "drifted" i use the term losely and are being sold off for parts.
Or try a nissan dealer. It would cost you a pretty penny i would dare say though.
ive had a quick look on here in the f/s section and on ns.com but couldnt find anything. If anyone does see an add of a wrecking r32 could u please pm me..
It did take some skill to hit it, lucky it was only the light
EDIT all good, found some!
Edited by wyzokie
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
