  • Replies 6k
Posted Images
heh, im working tonight, bah.
tomorrows an actual day off, which is pretty sweet, havent had one in a while :rolleyes:
oh, anyone know toyotas? im looking at buying a UZ soarer (the price is right and im in desperate need of a car that isnt shit), but the front airbags have recently start leaking, anyone know how much they are to replace?
Soarers are pretty expensive to fix I hear, parts availability being the main issue, but with any twin turbo car thats the case...
lucky im not buying a JZ...
Have heard that airbags are anywhere up to $1000 a corner ($4k full car) So be VERY weary of that. Ring Lexus and ask how much to replace the airbag on the LS400 (same car) to get an accurate idea.
yeah, i was afraid of that, i was thinking about $700-$1000 a corner.
might have a look at some aftermarket equivalents also, see if theyre any cheaper.
but then, for the price of the car, even if i replaced all 4 airbags itd still be well under the usual purchase price of the car.
Edited by scandyflick
The coil packs are in and car is back up and running better than ever.
Highly recommend changing coil packs to split fires as it made a massive difference to my car.
Now it is in get the front bar fitted ready for auto salon.
Hmm nice...
Cause I have a mis fire issue at the moment in the GTR so might be upgrading the coil packs to splitfires and they are good!
Did you have a mis fire shaun? or just upgraded for the hell of it?
not at all, just the soarers come up for the right price, and im sick of driving a car where almost nothing works the way it should.
Phew!!!
Yeah it does come down to price doesnt it...well I hope it all goes well ;)
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
