thanks Jess
have you had a chance to look around @ 5 stud hubs
i found a topic but cant find it quickly here basiacally some guy selling front struts to stagea with
R34 fron rotors and calipers and rear 33 gtst hubs and calipers
ive got my front rotors and calipers will talk to a guy about getting his rear end rotors calipers and hubs
then to my knowledge all i need is front hubs to suit ATTESSA
Yeah I did and I can get them but the GTR 5 stub hub will only fit on the front
so looking at another option for you and will get back to you asap
sorry just so dam busy at the moment have no time to post at night
  • Replies 6k
Posted Images
yeah that is fine as i said i will be getting GTSt ones here locally
its the front that gets tricky, do GTR hubs suit GTS4 axels this needs to be confirmed
well got my new clutch in my car....
xtreme 6 puk ceramic button with 1600kg pressure plate, chromoly lightened flywheel.
The best single they make, its a right royal pain in traffic as its either stall it or chirp as you take off, but its an awesome clutch with the lightened flywheel the thing revs so so quick
cheers madaz. Saw the pics last night, was too tired to reply - but they arent showing up now?
Weird seeing my car in different colours lol but i stuck with the first one u did (original colour :D ) Thanx!
There Back up you must of just caught it @ a bad time :rolleyes:
very quiet he must have the flu1
anyways flick got down a couple of variations see what you think
yeah some brakes parts are on ebay from a stagea.....
Have you got a Link Brendan
nope....the pamphlet states......
Maximum performance,
minumum driveability, apparently its the one all the top drifters are using
gunna start drifty'rosa now :(
Jess >>Here<< is the thread with the parts for sale and what made me think stagea but i dont need the whole arm bit do i? i can use my original components and just bolt on new hubs yeah?
looking @ the most cost effective way of getting conversion dont so i can save up for new rims and hopefully get this upgrade before hell freezes over
If it's still a PITA in traffic, can I ask why you decided on a single and didn't bite the bullet on a multi plate?
