  • Replies 59
Fatz,
When I blew up the GTR this time last year, and I had the orange avenger (thanks again by the way), myslef and Tam took it to the creek, that car was an 11 sec beast, you just dont know how to drive it!
I think we should make an SDU spoff of the "Fatz and the furious" I have some remote R34's and supra's which will be perfect for the stunt sceens.
What do you think?
  • 4 months later...
I swear that if you were in Vic I'd help fund the project :D
I want to do the same thing to my g/f's Corona (81 model I think)!
Holden 1.9 ltr engine and 3 speed trimatic... take it above 70km/h and the thing whines and starts shaking apart :D
I reckon a 2ltr turbo... or a V8 would do the trick quite nicely, but need to wait to gather all the parts before her old man and I have a crack at it :(
good luck FATZ, if I get this beast up and running I'll come up to NSW and own you down the Creek!
Prepare yourself for 28 seconds of ownage FATZ... LOL :)
Good Luck and keep us posted !
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
