Hey guys
Happy new year to all
before chrisy i installed my poncams and got a tune expecting a nice fat midrange with a strong top end as the cams are designed to do. yet i was missing 50 kws from my previous tune with the standard cams.
we got the pfc boost kit working well with a fairly constant 24 psi, but the dam thing just wouldnt make any power.
i dont have a printout of the run, but it was making slightly more power down low then up past 4500 the old graph left it for dead.
previous graph with gizzmo boost controller was 317 kws
new tune with poncams and pfc ebc is around 270 kws
gizmo tune was 26psi droping to 24 psi at redline
pfc ebc was constant 24 psi to redline
also the power was dropping off slightly past 7k whle with the standard cams it was still pulling hard at 7300
"ITS NOT THE CAM TIMING"
i have checked, spun the motor and re checked.
Just a thought.
What have i changed between the old cam tune and the new tune?
Poncams
new 4 inch stainless intake from q45 to turbo
PFC ebc
Full Auto trans build by MV auto with a 3k high stall.
So i wonder what difference the built trans is having on the dyno?
Whos got a crystal ball thats works?
Cheers
Darren
https://www.sau.com.au/forums/topic/149251-rb25-poncam-issue-missing-80kws/
  • Replies 41
Posted Images
maybe the tuner hasnt changed the maps enough?
is the comp setup for the q45?
what is the airfuel doing on the graph where it dies down to 270kw?
Old tune had the q45 on it, i have just changed from a 4 inch silicone elbow to a 4 inch stainless elbow.
AFR over 4k its 12 dropping down to 11.5 at 7300rpm
no i havent used a dial gauge, just set them both at zero.
i had the head apart when i did my full rebuild and all the standard springs where measured and were all in top nick. as the car from new hasnt done 50k yet.
so i was thinking it wasnt the springs as the cams are designed for the standard valve train.
From what i have seen, high stalls dont work well with dyno's, dynod many cars with them, and they never seem to make the power they should. I dynod an XD recently which made heaps of noise, and only 260 rwkw, but that night ran an 11? Does the car feel noticeably slower in the top end? 80kw should be very noticable in the seat of the pants dyno?Should make more power down low, as thats the torque multiplication doing its job.
Same dyno yeah?
yea same dyno
we overlapped the old tune and the new one but i didnt get a copy of it.
new tune started off better then crossed the old tune about 4k ish then followed it up to redline but slowly lacking more and more power.
old tune with standard cams
The cams 'will' require adjustment and when you do adjust them you need to alter timing and fuel maps to suit. The timing map you had of the stock cams will not work well at all for example if applied to the new ones.
You 'must' invest in adjustable cam gears if you have not already, at least on the exhaust side.
The cams will increase the engines airflow capacity without question if setup correctly, that is the good news.
SK reckon's they are best set at standard?
but having adjutment will be handy so i will aquire one.
"The cams will increase the engines airflow capacity without question if setup correctly,
that is the good news"
was there bad news coming?
I think if you ask SK, he's going to tell you the same thing. His comment reffered to a particular cars setup ,one totally different to yours. It was a Neo motor for a start. Even if I owned a neo engine I certainly wouldn't assume that 0 and 0 are right for an application where turbo selection and high stalls are involved. Engine loads on the new stall will play a part in changing the game.
Always explore cam timing changes no matter what engine, you can do so much to the power delivery by altering it.
Having said that if you didn't alter the timing map significantly for the new cams then there is no question you have a massive issue right there. It is critical to good power with the larger duration,lift and overlap cams you have especially up top in the rpm.
My guess is you are going to end up with quite a bit of adjustment on the cam timing given the airflow target is above 300rwkw.
I'd expect to see as much as 100hp+ peak power or so improvement over the stock units at the same boost once they are setup right.
Darren,
The converter aside how smooth is the top end of the graph?
Nice and smooth? I've noticed as valve float occurs that's not really noticeable (i.e pumping up lifters or massive nose overs) the graph tends to start to wobble up and down slightly away from the usual smooth curve and as you dial in more boost power doesn't pick up as it should.
The valve springs may appear in top shape but for the boost you are running they will be nearing the limit.
Some with rb25 heads begin to float at around 20psi others have no issues up to 25psi. It 'may' be possible the cams have a slightly more aggressive ramp rate that pushes the springs just over the edge *slightly*. Enough so that it just won't make any more power even if you dial more boost in.
Pushing more and more boost in will have power nose over hard and it will pump the lifters up.
Its going to be a pain in the arse to diagnose as it a few changes have been done at once. :)
Hows it go if you dial in less boost? Big power drops or?
270rwkw through an auto.. I'd expect that to be done on around 17-18psi behind an auto.
I think 32's you have to dial in some degrees, R33's are best on std, R34's I don't know thats on a gtst, gtrs are different again..
My R33 is on 0 degree's and works fine. It was originally set at -4 degrees and I lost 30rwkw, reset to 0 and found them again.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
