since they are 2 licences (motorbike and car licence), dont u loose ur motorbike licence and get to use your car licence then?
Your car/motorbike & boat liciences are all tied together...
I was breath tested this morning at caloundra at the boat ramp before going wave jumping on the jet ski... First time this has ever happened, but the water police did a check on my licience number to see that I have done the latest jet ski licience update and that I was on an open licience... I blew 0.0 tho as i didnt have a heavy night last night... But its the same rules as the road when on water...
The only licience I have that cannot be taken is my 14t forklift ticket... :P
https://www.sau.com.au/forums/topic/149259-fugg-it/#findComment-2785207
lol forklifts on road is not good. a friend tried it. first corner and it flipped. then again he was doing 60k's down the markets at the time and they are rear wheel steer :D
he doesnt work for the company anymore :P
https://www.sau.com.au/forums/topic/149259-fugg-it/#findComment-2786786
lol bl to the motorcycle license.....hope you learned you lesson
:P or atleast plan to revenge it somehow with some cheekyness
neways never mind man, everyday is closer to get your license again
lol yeah forklift pimping for the win....but taking it for a spin on the nice tar out there is a baaaaaaddd idea :rofl:....funny
but oh so bad
https://www.sau.com.au/forums/topic/149259-fugg-it/#findComment-2791752
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
