  • Replies 2.1k
Posted Images
ummmm... yeah
wtf?
Honda F1 introduces elephant ears
03 May 2007
On the final day of testing Honda introduced a radical wing on the nose of the RA107. Honda's test driver Christian Klien is out in the car today at Circuit de Catalunya today to test the new 'elephant ears'. Whether or not the Honda Formula 1 team will use the new wings during the upcoming Spanish Grand Prix is uncertain at the moment. It is interesting to see though the team saved their new wing to test it on the fourth and final day of testing
Another good reason to cut aero as much as possible, they make the cars look damn ugly. Was looking at pictures of the 88 Mclaren (MP4??) and it is simple and elegant and beautiful.
The 88 McLaren was the MP4/4. Actually all of Ron Dennis' McLaren are part of what he called project 4 - needless to say the first three didn't work nearly so well. The car itself was designed to a fair degree by Gordon Murray & a number of others who's names don't immediately come to mind. I think John Barnard had either gone or was in the process of going to Ferrari.
Anyway with two hacks by the names of Senna & Prost the thing won 15 of 16 races that year.
For my money, however the prettiest McLaren of all (M6A aside) was the MP4/13 which in pre-season testing wore the traditional McLaren orange along with the West sponsorship logos.
yeah I saw the BMW F1 nordshlieffe laps on TV. looked awesome, but damn, 8min 34 seconds??? did he park on the back straight and have a quick smoke?
I read something on F1 live that BMW 'dummied' the car a little bit. Harder compound tyres, increased ride height and brought the motor's max revs down, apparently it could still do 300km/ph, but cornering and high speed balance/grip was lowers so it wouldn't be so 'dangerous'.
No offence, but I wouldn't mind seeing Monaco off the season list.... Keep Silverstone!
Bring back the twin German GP's!
Oh yeah, Singapore has been confirmed for 08 as well!
If anything, I hope one day we'll see Zandvoot again, great racerack!
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
