i wanna know
stocker GTO twin turbo 4wd v6 3l... vs stocker r33 GTR twin turbo 2.6l straight 6
who wins drag? circuit? any comments
i know the 1990 gto has much better tech with active aero and active suspension (apparently the suspension lowers it self and the front lip comes down AS ive been told by someone who is selling his car)
go go go answer my q's
https://www.sau.com.au/forums/topic/149603-mitsubish-gto-vs-gtr/
I belive all thing that are good about a GTO is what also makes them such a pain to mod stock for stock GTOs arnt slow and do 100kph in 1st but still think a GTR would win all. GTO has more wiring then is good for it i wanted one before i brought my GTR but very lttle info about mods out there.
Agree with GorGasm 100%
I hear they have a glass transfer case that costs you a kidney when it breaks also :wave:
Not only that, the gearbox is not the strongest either - you'll find many GTO/Dodge Stealth owners have had the gearboxes reconditioned/rebuilt.
GTOs look nice but they are heavy, don't handle too well and expensive to maintain - basically Mitsubishi's version of the 300ZX
you're going to get a bias opinion on a skyline forum... but here is my opinion, might be biased since i've never owned a GTO..
They look nice - one of the guys in sau vic has one, looks hot, and goes well, very responsive, being 3L.... but i belive they are heavy compared to a GTR, handling isn't quite GTR class, and they cost a lot to make go fast, mainly because not many people have put the R&D into them here compared to GTRs....
gtos look wider than the gtrs on the street - they look good, but i reckon they go crap when compared to gtrs. They are too heavy - but can be modded to do some fast times. Interior looks way too daunting for my liking..
I own both cars, i think the GTR is a true race car out of the GTO but GTO does have lot more torque compared with the GTR.
But as as daily i would perfer a GTO because the ride is much nicer and comfortable than the GTR but if it was race track i would choose the GTR.
I DRAGGED A GTO IN MY OLD CAR (SUPRA TT , COOLER EXHAUST, CLUTCH 20PSI BOOST) HE LAUNCHED HARD OFF THE LIGHTS BUT AFTER SECOND GEAR HE WAS NOTHING TO ME AND THEATS IN A RWD CAR I RECKON THAT THEY ARE PRETTY SLOW AND HE WAS NO YOUNJGIN LIKE ME HEA WAS LIKE MAYBOE 30 SO I WOULD IMAGING HE WOULD HAVE A LITTLE MORE EXPERIANCE THAN A 20 YO KID
oh dear.....
I DRAGGED A GTO IN MY OLD CAR (GL Lancer - heaps of stickers - 4 inch tip on my stock zorst) HE LAUNCHED HARD OFF THE LIGHTS BUT AFTER SECOND GEAR HE WAS NOTHING TO ME AND THEATS IN A RWD CAR I RECKON THAT THEY ARE PRETTY SLOW AND HE WAS NO YOUNJGIN LIKE ME HEA WAS LIKE MAYBOE 130 SO I WOULD IMAGING HE WOULD HAVE A LITTLE MORE EXPERIANCE THAN A 12 YO KID - Then i wet my pants and woke up......
yuck........
great story...seriously, great story............................................................. :(:no:
The only down side with the GTR is to many P-platers own them. Especially ones that public education has failed.
damn school holidays.
awesome post. def read again
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
