  • Replies 40
Posted Images
Yesterday i went out and i couldnt find that thermofoam anywhere.I went to rocket and bought some stuff called thermo-mat.Its foil on both sides with what looks like fibreglass matting in the middle.Cost me $50 for a 120cm square sheet of it.Anyway i measured it up,cut it out and put it in the CAI.Havent really driven it much since then but surely it would do something.
How did it go ducting the air in from the side? Do you know how the guy that did that find it? Where would the CAI hose run if I did this?
I would prefer to use the stock intercooler holes, but I have the Blitz kit which uses them, and I don't have a stock snorkel.
sorry to be a wet sock, but, that is still going to draw heat in from the headlight at night, is it not?
Im in the process of trying to "think" up a completely "sealed" design, with only one air intake through the base to use the stock intercooler piping hole as a cold air intake point. Will be fabbing it up at work (work at a sheetmetal place :dry:). Will be a bastard of a job i think =[
Compared with engine bay temps, I think the heat from the BACK of the headlight would be negligible. Remember that one day you will probably have to change a headlight bulb so make sure if you put somethign behind it that it is easy to remove. If you are that worried about it I would just tuck some foam in behind the headlight and secure it at the corners.
Hi mate,
Where abouts did you get the ALUCOBOND (im in tassie 2)
cheers
Well so i was sitting on the net, going over all the CAI designs, ones you can buy and so forth. I remebered that a member of the forum had some templates. SO got those and went to work.
My dad and I started in the morning on boxing day, figured we would take it easy, well 4 hours later, and a six pack of beer, and HAY PRESTO, here is the finished result.
The box case is made out of a product called ALUCOBOND, it's a 1mm ally, with 3mm PVC, and 1 mm ally again. You can buy a thicker ones if required. The inside is lined wiht a THERMOFOAM, it's a 15mm thinck high density foam with silver foil, excellent R values, to miniminse heat transfer. I noticed a 6deg C after introducing the foam.
The air is introduced through a 2'5" pipe from the front of the bar and blows straigh into the box.
SO far the results are great, the car is a lot more constant, if you stand in trafic, the heat lag is gone. The air is nice and cool, and the car is a lot more responsive. Fuel ecconomy is up, and the pod noise is reduced to a more acceptable level.
Only down side, on a cold morning, the dam thing hits R&R so dam quick, as the air is so dense, and the box together with the FMIC, really increase the air flow, hence R&R.
I have the templates available, if people are interested, but i modified mine as i went allong, i found that each car is different. I have done this to my friends R33 4door, with an APEXI filter, and we had to extend the main box body and make a different cover top.
I did mine by making the side first and then making up a pattern to fit for the top cover. The side of the box is held in place by two brackets riveted to the side of the box, and bolted to the car using the stock airbox mounting holes. The top is slid inot place under the front panel, and then bolted through the top, into some brass L-brackets. I then finished the alluminium by brushing it with fine still wool. I did have it polished, but it was VERY hard to keep semi clean. Total cost, ALUCABOND, free i got offcuts, Thermofoam $36 per meter, and all the other bits and peices i already had, so that is DAM Cheep.
Tell us what you think.
woolls, i'll get some on monday, you can only get it form TasCon on argyle street and i know the guy so i can get it for free, or you can go in and for a carton of beer you can have as much as you want. offcuts ofcourse. PM me and we'll chat
Any tiny bit of heat you can get rid of can help, the colder the better :)
Either the foam or just a detachable/screw in section.
Any tiny bit of heat you can get rid of can help, the colder the better :laugh:
Even with the thermo foam etc in place you would still get a lot more heat coming through the shield than you would get from the headlights,
If you do decide to shield from the headlight please post results. I would guess there would be no noticable difference.
the amount of heat of the headlights would be sweet F.A. the rear of the light is plastic, which doesn't conduct heat well. if you put you hand over the back of the light it will only be slightly warm.
you would get more heat radiating off the intercooler pipe that runs from the turbo to the cooler.
as for making a completely sealed box, i'm undecided on this. sure you wouldn't get any hot air coming in, but if you don't have a big enough feed at high rpm it may end up being a restriction. if you don't have it set up right at WOT at high rpm you might be only getting 90% of the air that could be used. if it isn't fully sealed in the same situation it will be able to get 100% air. and the small amount of warm air is going to be better than not enough air.
Agreeing with MAD082 that plastic is a bad conductor of heat, that’s why I decided to make my CAI box out of acrylic. As most stock CAI boxes are made of a plastic which must have some purpose or reason. Otherwise wouldn’t all major car manufacturers make them out of some other material?
looks great mate...well done.
as for heat from the lights...lol it would contribute sweet FA and only be an issue when the lights we ON...
not withstanding...the amount of air comming in and the heat it would disipate through the plastic backing would amount to FA.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
