I just put a turbosmart bov type2 on my r32 and was shocked with the results
first of all the car DOES NOT stall while driving, the only time it stalls is when 2nd gear is revved out and i put it back into neutral n let the car roll the revs just die n the car stalls but i have tried this with every other gear and it is fine, have no idea why this happens
car runs alot better, pulls harder
the car is drinkin alot more fuel (maybe coz i've been goin sick)
and it sounds good
overall was worth it
https://www.sau.com.au/forums/topic/14982-bov-on-a-r32-results/
Hi guys, let me get this right, there is a line of thought that says you don't need a BOV at all?
Or is it that the standard BOV is better recirculating rather than venting to atmosphere?
Or is it that an aftermarket BOV offers nothing over the standard BOV?
So let's investigate...
No BOV = stalling the turbo is OK? I don't think so.
Recirculating BOV = all that hot air going around and back through the turbo again to get even hotter. Doesn't affect the performance, I don't think so.
No matter how big a turbo you put on, the standard BOV is always big enough to vent all the air fast enough to prevent the turbo stalling. Once again, I don't think so.
Anyone who has driven a car without a BOV will know that there is a noticeable delay before the turbo regathers the 70,000 or so rpm it looses on gear changes. In a circuit race car with 20 or so gear changes per lap that is enough to loose a race by a lot. Even the three or so gearchanges down the 1/4 will have a noticeable affect on the time.
So next time someone tells you a BOV is not a performance device, you can say .......................
Guest INASNT
so after all that u r saying its a performance enhancement??
I would rather have minimal semi hot air recirculating rather than none at all! I had a blitz supersonic and it sucked balls
Old BOVs, as all things old age and CAN start to leak. I was always happy running std BOV, but recently installed an Apexi for the following reasons.
1. Car was starting to run a little doughy and didnt boost as hard as it used to.. .was it me getting use to hp, mech prob such as plugs or was the BOV leaking?
So i blanked off where it circulates back to behind filter, and tapped in a pressure gauge, (cheapy from work) and went for a drive, the valve was definitley leaking as the gauge was reading a pressure as i gassed it gear after gear.
2. For track days wanted to see if there was any truth to intermittent rich mixture cooling piston crowns, and may delay onset of water/engine temp probs at track.
3. As Sydneykid said, air being vented back to inlet tract has already been compressed (heated) once and despite intercooler will never be as cool as ambient air. My car pings so in additon with point 2, cooler air & cooler piston crown, well wont stop pinging but every little bit helps
... with some playing under the bonnet, starting with softest spring setting, kept tightening the pre-load screw until car no longer stalls...
As for performance gain, if the original (or an old BOV) is leaking then it will be costing you power, funny how 1 year ago everyone was saying BOVs are the go, these days everyone is sworn off them! Cycles i suppose.
Guest INASNT
Hi INASNT, me, I'd rather have no hot air recirculation.  Remembering that every 8 degrees is worth 5% in horsepower.  We find it worth the effort to tune out the problems.
Each to his own.
how do u tune out the stalling problem with atmo venting blow of valves when u r running around 450-500hp?
Hi INASNT, you asked "how do u tune out the stalling problem with atmo venting blow of valves when u r running around 450-500hp?"
Horsepower is pretty irrelevant really, the tuning methodology is the same regardless. I will assume that you know the causes of the stalling and move straight to resolution. If the following doesn't make sense, just ask and I will try to fill in any blanks.....
When you snap off the throttle the TPS reads 0%, the engine RPM is way above idle and excess fuel is delivered because of the AFM reading. It is also most likely running on a TPS vs rpm driven ignition advance (depending on the ECU) . What we do is lean out the mixture at those points on the fuel map and advance the ignition timing. We resume normal parameters at slightly above idle rpm (say 1400 rpm). You may have to fiddle with the exact fuel and ignition values until you eliminate the problem. It is sometime necessary to raise the idle RPM, 100 to 150 rpm seems to work OK.
We also find it helps if the lambda sensor is in good condition, a dirty one slows down the response and exacerbates the problem.
Hope that helps.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
