Kws At The Wheels
219 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 152
Posted Images
geebus! some of yous have some serious power! i'm shitting myself in my little 80kw mx6 turbo around corners (that is with a blown head and running at 2psi hahahaa) and some of yous are hitting 300kw mark! damnnnnnnn
:) i think my mates MX6t makes 106 FWKW
:( i think my mates MX6t makes 106 FWKW
that's alright but i haven't hooked up my boost controller and it needs some head work! and plus there's a leak somewhere which is causing me to loose boost! well maybe i might make 120fwkw boosting it to 9 psi because of the larger turbo!
maybee hes running no boost controler also but its got a VJ11 on it which im led to belive is basically same size as orriginal
EDIT
just googled VJ11 and it maybe the standard turbo looks like they can 18+ psi
Edited by Madaz
Got it running again last month(slo 31) 370rwkw now with powerglide, but i picked up another
100nm of torque at the rear wheels(700nm) due to the more
efficient torque converter, Unbelievable ...the extra torque make
pretty much undriveable even on 275 Mt/et drag radials, should go
400rwkw pretty easy on pump fuel in the coming months if the stocky bottom
end holds up, it would probally make 400rwkw now if it was manual or even now how it is
on one of adelaides more happy dynoes
R31 skyline..370rwkw on 23psi(37 degrees weather)- boostworx
cheers
darren
Edited by S3_Girl
oh yeah pity about no AIR
any news on that going through the courts
i think everyone should stop buying bob jane until he sells ... but that would assume that we go there :) to whick i know i dont
Yeh i heard today that Bill has won the court case.............. F#@K YEH!
and also heard he is gonna bulldoze the whole joint and run the strip down the other way! and something about putting in a jet sprint track in the middle of the cuircit! BUT not sure when all this will start! BUT WHO CARES.............. HE WON THE COURT CASE!!!!!!
lol my bad.. GT42r... Lunatic. :nyaanyaa:
Yep a powerglide is going in behind it as the r33 auto built up had issues holding the power. Not surprisingly really as 373rwkw is a rather large amount of power. :P
gt 40/42r to be picky.........I heard the powerglide was already in and made something over 400rwkw?
Sort of. :nyaanyaa:
cheers
darren
GT42/45 actually, 400rwkw, love the rumour mill, it had a 10 minute tune and then shaun shut
his doors for the year, he was already running heaps late, goes back next week for 90/10 shocks, adjustable rear control arms
R32 4 spot brakes and more power:)
cheers
darren
Edited by S3_Girl
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
