Kws At The Wheels
219 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
yep what a day, worked out in the end
Full boost before was at 4250rpm, think it is the same still , don't know to busy watching
the road:)
I can get 20+psi on just a footbrake if i want, no point though, anymore than 3200rpm
and 3 psi and it digs a hole on mt drag radials
  • Replies 152
Posted Images
the road:)
Darren, How much of an exhaust and what size you running?
Daz, tell the real story. It was 471.3rwkw - that point 3 can make a big difference :rofl:
Three 450-470+rwkw runs, back-to-back and in 40+'c heat. Impressive stuff.
Edited by whatsisname
4 inch dump, 3 inch exhaust full length of the car, 1 big muffler
and a little muffler at the back, i have no intention on ever using no
exhaust and race fuel..its a street car, and a challenge.
first pull was 460, then 1 or 2 degrees of timing 471, was there a 450?
can't remember
cheers
darren
Edited by S3_Girl
hey just like to update me kw output lol
well ive had my car tuned with the powere fc logit the other night and am running 1.3 bar std turbos
starting to make boost at 1900 rpm and full boost by about 3300 rpm and comes on pretty hard for std
the power fc logit is the way to go for sure i have no knock and and pulls hard all the way to 8000
prolly around 280 to 290 + easy
see how long b4 i need new turbo's
mike
So a guy is sellin his S15 and uses my dyno chart as proof of the power...
http://forum.silviansw.com/viewtopic.php?t=26296
Damn funny read.... :):D:O
Becareful guys!! Who woulda thought this shit would happen!
:laughing-smiley-014: the dumbass [insert OWNED!! image here] :laughing-smiley-014:
If he was a little smarter he could of at least photochopped it - Hi Tech Dyno, file name, power figure etc.
Nice one Busky2k.
can't remember
cheers
darren
Darren, Troy just told me the other day you have only just changes the stock brakes to 33 ones, WOW how did it used to pull up?? Ok?? Must be alot better now with that much power and now brakes you can trust...... :D
Damn funny read.... :nyaanyaa::nyaanyaa::laugh:
damn
you should reply the thread...to protect the buyers imo
nice find tho'
your car back yet andy?
nah paul...dropping it in today, if the clutch arrives
got held at customs for 7 days now (and $500 for duty + gst)
to "protect" the local business...but the thing is, nismo clutch can only be bought oversea, not made locally :nyaanyaa:
way to make money
ok time for ppls thoughts
a mate of mine his R34 made 147RWKW @ the last dyno day and that was running stock boost
he has since got another tunner to put a boost controller on just the bleed type and a fuel cut defender and now hes making 204RWKW from a NEO ive spoken to a couple of others and i really didnt think just winding boost up to 14psi on a neo would get you over 200kw
anyone elses thoughts on these NEO engines
Its around the mark considering its running the fcd. BUT 14psi is iffy on the R34 turbo.
Generally 11psi ish makes that sort of power (maybe a touch more as the R34 turbo's ted to push 10-15rwkw more than the rb25det turbo's so 210-215rwkw) when ign and fueling is optimal (ecu).
Hey Madaz
Yeah sounds right. I'd say though between 12 and 14psi he would have about half a kw difference! So he should probably put the boost down a little before things go bang.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
