Ive heard a lot of friends talk about this place not far from Richmond that they call Magnetic Mountain where you park your car on what looks to be a downhill slope, get out of it and the car will start rolling up towards you very slowly as if its being pulled toward you by a magnet, so myself, d0p3y and DJX thought we would go their lastnight to give it a go and its one of the trippiest things we had all ever experienced,
Theirs some crazy optical illusions at work here it genuinely looks like your car is rolling up a hill towards you like its being pulled by some massive magnet. So has anyone else here ever been their and if so what did you think of it? for those wanting to know how to get their just go to this link below:
Mountain
https://www.sau.com.au/forums/topic/150085-magnetic-mountainhill-richmond/
  • Replies 84
Nah no pics or vids unfortunately it was too dark we were their at about 1am, its kind of hard to explain which part exactly it happens at but if your coming along Grose Vale Road you turn left onto Bowen Mountain Road and you will see an intersection about 50 - 100 metres up or so you go past this intersection and you will see the road start to slope downwards, go down this hill about 50m then turn around and face your car back in the direction you came from turn the car off and leave it in neutral then run back up the hill and if your in the right spot the car will slowly start to roll up the hill towards you gradually picking up more speed,
Just make sure you keep a lookout for any cars coming towards you and make sure someone stays in the car to jump on the brakes incase the car rolls off into a fence or something because your in the wrong spot.
Its about 40 - 50 mins from where I live (Mt Druitt area) It only takes you about 5 - 10 mins from Richmond or if your in Penrith you could probaly get their in about 25 minutes.
Directions
The Richmond Magnetic Hill is located on Bowen Mountain Road in the Township of Mountain Bowen, just east of Richmond. The hill is located at the Mountain Bowen Rd. and Westbury Road intersection. It only works for about 50 metres going uphill.
Directions from Sydney
From Sydney City, Take the Harbour Tunnel or Harbour Bridge, follow the Warringah Expressway straight through to Lane Cove, and follow through onto the M2 Motorway right to the end till the Blacktown Exit - Turn right onto Burns Road which follows onto Old Windsor Road, which runs into Windsor Road, turn right and it will take you right into Windsor. In Winsor make a right turn onto Winsor Richmond Road (40) and it will take you to Richmond. In Richmond 40 becomes Kurrajong Road. After crossing the Hawkesbury River in North Richmond turn left on Grove Vale Road. Then turn left on Bowen Mountain Road. The Magnetic hill is on Mountain Bowen Road as soon as you pass the intersection with Westbury Road
Whereis is your friend click here
I might go back their tonight to show my GF so if I do I will take my camera and try record it im not sure how well it will turn out though as its pitch black around their at night.
This post is uselss without Video
Well if its not good enough for you go make one yourself :(
Just yeah if anyone goes play around with it for a while to make sure your in the right spot etc coz if your on a different angle or something it can look completely different and not work so just try a few different areas first.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
