good stuff. do some lessons and u will learn the proper way to drive, then u wont pick any bad habits up when u go for your licence. just remember u only have to go for your licence the once, then u can drive how ever feels comfortable for you. but up until you get your licence, try to drive like the rule book says, then u will definately get it.
im gald im not the most inexperianced driver here....pwew!
i drive everywhere, right now just getting used to tricky lane changes and everything that involves slow large turns....aka parking reversing out or driveways u-turns in streets etc
aparrantly my gearchanging isnt as great as i thought it was......
love you ian!
Oh yeah, so good luck man, we'll see you out on the road in no time
im waiting for some good incomes to get me some lessons, my dad learnt australian licence rules 16 years ago, and before that was in the army in poland.......so really she pulls me up for little things like hands on 11 o clock and 2oclock "i should be doing" but really the test doesnt care more or less ....(depending the dude guy thing *blonde moment........blank*)
but so yeah, good on ya man, if you need any hints call on us
Edited by ze_flexy_1
seems alot of people want to know ill try and write up the PREGO how it was started thread
but tonight what i didnt mention is my mate at work has a v8 vs ss comodore ute which is na but has quite a few mods
and he let me drive it out the back of work its automatic and i stayed in first
didnt go fast
but had the time of my life was so fun im very lucky he let me drive it
just waiting for damo to drop the same favour :laugh:
^^ know he wont but i can try
Just remember dude. Hands at 9 & 3! 10 & 2 is old school, if your parents or driving instructor tell you otherwise they are just simply wrong, hands at 10 & 2 means if the airbag goes off, it hits your hands/arms and does a lot more damage.
So 9 & 3 :laugh:
BTW, do a defencive driving course as soon as you can! It will help.
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
