  • Replies 47
Originally posted by JUDGED
Strich,
You are only a snap of the fingers away from a get time, your'll get there. Did you get my PM dude???
Yeah, hope so with the new clutch n CAI (must take pics too, dam)
got your PM too dude *taps nose* well done!
hehehehehahaha - i can sense that paul is feeling a threat.. :) but then again, he'll probably pull out some more boost on me again and kick my ass.. hehe...
rev - the 13.6 "felt" slow.. it bogged down a little at the start.. i used lauch revs of 3k.. with the state of the clutch and me still being able to run two 13.7 passes after dad cooked it, it makes me think something could have been slipping.. hence that extra .1 or .2 could be within reach with a new clutch..
also i had about 30-40kg of tools in the boot when i did that pass - not to mention at least another 30kg of stereo.. :D
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
