  • Replies 47
Originally posted by JUDGED
Strich,
You are only a snap of the fingers away from a get time, your'll get there. Did you get my PM dude???
Yeah, hope so with the new clutch n CAI (must take pics too, dam)
got your PM too dude *taps nose* well done!
hehehehehahaha - i can sense that paul is feeling a threat.. :) but then again, he'll probably pull out some more boost on me again and kick my ass.. hehe...
rev - the 13.6 "felt" slow.. it bogged down a little at the start.. i used lauch revs of 3k.. with the state of the clutch and me still being able to run two 13.7 passes after dad cooked it, it makes me think something could have been slipping.. hence that extra .1 or .2 could be within reach with a new clutch..
also i had about 30-40kg of tools in the boot when i did that pass - not to mention at least another 30kg of stereo.. :D
