  • Replies 46
Well what a bitch... car started doing it again when I went to get lunch =( Assuming it's either the second AFM or the first one is not soldered well enough, will rip them out again tonight and take a look.
I'm sure this is a test of faith =D
You asked when the stock one's run out of flow. The answer is they don't. The sensor runs out of resolution before they run out of flow.
I'm making about 300awkw on my high boost setting and i've already run out of AFM resolution. My AFM's read 5.1v by like 5-6krpm if I recall correctly.
If you have an adequate tuner because they can work around it past that point using what they know and judging by experience and things I don't understand really well. But this is not ideal.....
Past that power level you really need to upgrade to either Z32 AFM's or Nismo RB26 AFM's. A mate of mine was make 315awkw with standard AFM's but Jim at CRD highly recommended the upgrade at that point and I agree with him.
Pulled both AFM's tonight, bottom one looked like new, top one had some loose metal in it but the car still displayed those symptoms after being put back together. Trying a known working on tomorrow arvo and will get another one if it proves that my top one is forked.
Keep ya's posted
Might just sell and get a bloody clubsport or something :laugh:
yeah stock afmeters have been good to me for 416.9kw so far..
skylines are hassles to keep running right, fix one thing then about 100000000 other things go wrong(slight over exageration)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
