You know that long rubber strip that goes across at the bottom of the front windscreen, the right end is peeling off, do i need to get a whole new strip put on or can i use some sort of glue/silicon to stick it back in place
thanks
Edited by Hulk1010
You know that long rubber strip that goes across at the bottom of the front windscreen, the risht end is peeling off, do i need to get a whole new strip put on or can i use some sort of glue/silicon to stick it back in place
thanks
This has happened to me recently....Can anyone shed any light?????
manwhore, i think he is talking about the rubber strip that sits between the plastic clipped on bit and the windscreen.
in relation to the rubber strip, wait till its a warm day so its soft, then stretch it out and glue it back in place with epoxy or any type of glue that should hold.
mine cracked so i got mine replaced at a windscreen shop, it was not an original part as nissan told me that you can only get the rubber strip complete with the plastic part, which was more than $200.
the windscreen shop used a jaguar part, they glued it in for me and charged $40.
Is this what your talking about?
If so I fixed it with a rubber strip I got at clark rubber, they call it a mudguard flare protector or similar costs bugger all.
Ha....thats a smart idea... i am going to check out clarke rubber when i get a chance...my window seal is starting to break all over :)
Thanks R33S2 :)
dammit!! i guess i got a bit rorted! should have looked there to start with :)
Ɨ
Ɨ
