  • Replies 64
Posted Images
Niiice. 200+awkw with no hiflow turbo. Is that the bonus of manual and power fc?? Happy boosting!!
well cos its a rb26 engine in it not the rb25. I was being told that the rb26 are much easier to mod to get alot of hps
ohh ben told me that the car was only making about 150+kw@wheels before the tune and after tune its 236.5kw. So theres a gain at about 86kws@wheels.
Edited by stasis
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2828681
nice work - knew you'd be happy.
just a note - probably in rwkW - ben's dyno is a 2wd dyno :yes:
yea true but remember that he didnt disengage the 4wd. and all 4 wheels were on the rollers so i assume its still 4wkw though dont you think? :(
Thanks cruisy. Im real happy with it.
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2828890
Unless he has purcahsed a 4WD dyno in the past couple of months... there isnt 4 rollers on a 2WD dyno :yes:
Good result, RB26's can get some tidy power out with relative ease!
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2828939
excellent result. sounds like awk to me..... would have thought 236rwkw was a tad low for a tuned RB26dett, whereas 236awkw sounds about right. nice curve on the dyno graph as well, looks like a tune performed well by a professional. bad luck about the holdups but meh, Yudi Im sure you're happy at the end of the day :)
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2829292
Unless he has purcahsed a 4WD dyno in the past couple of months... there isnt 4 rollers on a 2WD dyno :sleep:
Just spoken to ben this afternoon and its a confirmed 236 :kiss: .5kw@4wheels
Edited by stasis
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2831560
thanks guys for the compliments.
Pictures to come as soon the car is washed and i will take a few good shots for everybody to enjoy note everything looks stock standard tough.
To the questions :
1. Mods i did was just a K&N drop in replacement filter, can gears and power Fc thats all of it. Ohh like wat tangles said its running at 1 bar boost with stock std boost controller.
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2831583
i dont know i didnt ask. If the man say it is then it is. Im just going by his wirds thas all.
Meanwhile we are at that i have been told to use 10w-60 Castrol. Can i use 15w-50 or 20w50? Its other brands not castrol i hacte Castraol. im thinking of using Mobil1 15w-50 or Amsoil 20w-50.
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832154
I saw the car on the dyno yesterday at Ben's, its definetly RWKWS..
Front wheels sit on a ramp, not rollers....
throw another couple psi boost in it and you'll get your 250rwkws, but risk blowing the turbos..
By the way, very tidy car!!!!
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832195
All the cars use Castrol Edge 10-60, the two motors he's done for me have, even before one was built
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832349
Thanks man. Well im just going by Ben's word and he said if its rwkw that will put it up to about 250kw. so...
Another thing guys fuel gauge. Just wondeirng when you switch everything on the ignition. Soes the fuel gauges goes down to E or it stays at the watever level is your fuel on?
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832933
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
