  • Replies 64
Posted Images
Niiice. 200+awkw with no hiflow turbo. Is that the bonus of manual and power fc?? Happy boosting!!
well cos its a rb26 engine in it not the rb25. I was being told that the rb26 are much easier to mod to get alot of hps
ohh ben told me that the car was only making about 150+kw@wheels before the tune and after tune its 236.5kw. So theres a gain at about 86kws@wheels.
Edited by stasis
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2828681
nice work - knew you'd be happy.
just a note - probably in rwkW - ben's dyno is a 2wd dyno :yes:
yea true but remember that he didnt disengage the 4wd. and all 4 wheels were on the rollers so i assume its still 4wkw though dont you think? :(
Thanks cruisy. Im real happy with it.
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2828890
Unless he has purcahsed a 4WD dyno in the past couple of months... there isnt 4 rollers on a 2WD dyno :yes:
Good result, RB26's can get some tidy power out with relative ease!
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2828939
excellent result. sounds like awk to me..... would have thought 236rwkw was a tad low for a tuned RB26dett, whereas 236awkw sounds about right. nice curve on the dyno graph as well, looks like a tune performed well by a professional. bad luck about the holdups but meh, Yudi Im sure you're happy at the end of the day :)
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2829292
Unless he has purcahsed a 4WD dyno in the past couple of months... there isnt 4 rollers on a 2WD dyno :sleep:
Just spoken to ben this afternoon and its a confirmed 236 :kiss: .5kw@4wheels
Edited by stasis
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2831560
thanks guys for the compliments.
Pictures to come as soon the car is washed and i will take a few good shots for everybody to enjoy note everything looks stock standard tough.
To the questions :
1. Mods i did was just a K&N drop in replacement filter, can gears and power Fc thats all of it. Ohh like wat tangles said its running at 1 bar boost with stock std boost controller.
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2831583
i dont know i didnt ask. If the man say it is then it is. Im just going by his wirds thas all.
Meanwhile we are at that i have been told to use 10w-60 Castrol. Can i use 15w-50 or 20w50? Its other brands not castrol i hacte Castraol. im thinking of using Mobil1 15w-50 or Amsoil 20w-50.
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832154
I saw the car on the dyno yesterday at Ben's, its definetly RWKWS..
Front wheels sit on a ramp, not rollers....
throw another couple psi boost in it and you'll get your 250rwkws, but risk blowing the turbos..
By the way, very tidy car!!!!
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832195
All the cars use Castrol Edge 10-60, the two motors he's done for me have, even before one was built
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832349
Thanks man. Well im just going by Ben's word and he said if its rwkw that will put it up to about 250kw. so...
Another thing guys fuel gauge. Just wondeirng when you switch everything on the ignition. Soes the fuel gauges goes down to E or it stays at the watever level is your fuel on?
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832933
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
    • Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
    • They're not rebuilt Racepace items. They were mint. From memory the were ex display stock that I bought off yahoo and he ran....from memory he barely used the REs when he replaced them with a set of Tein RS If have been stored correctly and not leaked fluid then they will be mint   As an observation the Racebuilt rebuilt Tein RA/RE/RS were a better street/club/track package. Really nice on the street and did good numbers at the track.  I think the factory Teins wont match the Racepace valving on the street but would be in the same window of performance on the track... albeit firmer
    • The one time that Clippy is actually useful!
